Thread: ytm200e forks swap.
    tripowersport's Avatar
    tripowersport is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2012
    pa
    292
    ytm200e forks swap.
    I have a Ytm200e and I need to swap the forks. Can I use my ytm200 forks down or do I have to and can I use everything? Thanks.
    Jun 2012
    pa
    292
    Also will the ytm200e fender bolt on the ytm200 forks? thanks.
    glendive, montana
    1,822
    yes and check the tire size between the two, if one is a 25-12-10, and the other is a 22-11-8, you will need to leave the triples, otherwise all of it will interchange. The 25 in tire ones the triple is a little bit wider to accommodate the bigger tire, and the fender will swap between them.
    Jun 2012
    pa
    292
    Ok, Thank You.
