Results 1 to 15 of 26
Thread: '84 Honda Big Red 200ES
    Jul 2012
    Texas
    21
    Hey everyone. I'm new to this, so bear with me.
    I have my grandfather's '84 Honda Big Red 200ES. We used to use this rig for hours on end in the cotton fields. He passed away in '89, but my grandmother told me last year that the Big Red was still around, and was at my aunt's house. To my surprise, it was in great condition!
    This three wheeler means a lot to me.
    I put a new battery on it, and it ran great. I keep the oil changed and perform maintenance regularly. My kids think it's the coolest thing around.
    Earlier this week, my daughter reported that it stopped running, and was leaking gas everywhere. I had her shut off the fuel valve until I could get there. Fuel was leaking out of the carb into the air filter compartment. I spent the weekend working on it, and thanks to the posts on this forum, was able to determine that it was a gummed up carb. I removed the carburetor, took it apart, cleaned it thoroughly with some carb cleaner I got at the store, and blew it out with my compressor. I put everything back together, and (after remembering to put the needle clip back in) fired her up.
    The leak is gone, but now she runs only with the choke on. She kind of chokes and sputters, and backfires a LOT--scares the heck out of the dogs. If I try to undo the choke, it immediately dies.
    Any ideas as to what's going on? Is there anything I need to tweak after taking the carb apart?
    Like I said, this trike has a lot of sentimental value to me, so any help would be *greatly* appreciated.
    Thanks!
    tripowersport's Avatar
    tripowersport is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2012
    pa
    292
    Try to re clean the carb They cant be REALLY tricky, go throw the jets with a little wire make sure its good and in the float bowl on the outer ring there MAYBE a jet in it clean that out also.You didn't bend the tab on the float did you the adjustment is 14mm from the bottom of the float to the flat side outer ring where the float bowl bolts on and make sure there isn't any thing in the float but i don't think there is. Make sure the needle clip In the slide is 3rd down from the top, The air screw is 1-7/8 turns out. Here is the manual http://www.oscarmayer.net/atc/manuals/ Do you have any pic's? Good luck and nice find.
    Jul 2011
    Ontario/Quebec
    1,179
    if that dont work a brand new carb for the 1984 200 big red is only 29$ on ebay,,just got one for mine and works great,,,just plug and play already all adjusted http://www.ebay.ca/itm/270920908058?...84.m1497.l2649 ....good luck!!!
    1986 Honda 350X
    1985 Yamaha Tri-Z 250
    Nov 2010
    newfoundland, canada
    13
    I agree with tripowersport, I understand the sentimental thing for these ATCs, especially with the fond family memories that come along with them. Get her sorted out and keep her forever with lots of maintanance, washings, and lemon pledge!!
    Jul 2012
    spokane valley washington
    27
    lemon pledge can't fix my machine. my 200es was flipped down a hill and we had to torch the bars and rear axle back into place. im having problems with her wiring
    MN
    3,263
    If its only running with the choke on you still have a blockage somewhere. Pull the jets and the mixture screw, run through everything again. Make sure the mixture screw is set right, lightly seated then backed out about 2 turns is a good starting point, you will have to do final adjustment after warming it up and getting it to idle, the you turn it out a little at a time till engine stalls, make a note of that point, turn it back in a turn or two so it will run again then get it idling and turn it in until it stalls, note that point and set it between the two points it stalled and that will take care of it.
    If all else fails get a new carb. For the cost of a rebuild kit you can buy a brand new one off ebay, about $30 shipped. I have one of those new carbs on my 84 200ES, the original carb is in pieces in a bucket for now. When i bought it the previous owner replaced the carb, i tried rebuilding the stock carb to put back on if needed cause it was running badly, after putting it back on it ran worse, turned out to be something else and i never put the stock carb back on because the new one runs better.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Jul 2012
    Texas
    21
    Thanks for all the quick responses.
    I took the carb back off, opened it up, and went after every opening with a piece of wire. Then I got some carb cleaner and with the straw, sprayed it into every opening and watched the cleaner come out the other side. I really don't think there's any way any of the holes could be clogged, but then again, I'm very new to this. I put it back on, and it ran exactly the same way: only with the choke on. When I would turn the choke off, it'd die immediately.
    Why would the mixture screw need adjusting when I never messed with it?
    Also, there is a piece in front of the carb that connects it to the motor. Part of it is a plastic-like tube that appears to have some cracks in it. Could that be part of the problem?
    Thanks again everyone for the help. Part of me wants to give up and take it to the junkyard, but I know I really should try to get it running again.
    Jun 2012
    pa
    292
    WHY!! would you junk it? It was your grandfather's means a lot to you, Get a new carb and maybe the tube or let it sit in side for a little then fix it. The carbs can be REALLY tricky! PLEASE don't junk it, If I lived close to you I would Help you fix it or buy it before you junk it, any one on here I'm sure would love to have it. Here is a new carb http://www.ebay.com/itm/1984-Honda-A...a03d5c&vxp=mtr , Just take your time with it and Good Luck!
    Jul 2011
    Ontario/Quebec
    1,179
    If the intake boot is craked that could be your simple problem
    It's sucking air!! Would inspect it a bit closer!!! Good luck!!!PLEASE DON'T JUNK IT
    1986 Honda 350X
    Pacific NW
    4,255
    Quote Originally Posted by RRaider95 View Post
    x2 on the vacuum leak,
    try spraying carb cleaner around the outside of the carb as it runs and see if it speeds up or dies,
    of which, neither should happen.
    The slow jets in those puppies is soo tiny, like .008 to .010"
    or like the smallest electric guitar string. and they'll refuse to idle and foul plugs.
    but to review, it ran great for a long time and then decided to leak out the overflow.
    so you'd think a fix on the carb float would fix it.
    but going backwards one step at a time, some crud from the tank probably
    got in the float valve. ok that's fixed.
    More crud got into the other jets but you say it looks great x2.
    Internal passages clear?
    ad yes, I understand the frustration.
    I had 2 carbs boiling away in the kitchen with water and vinegar over christmas and almost got divorced
    because of it.
    No matter how bad things get, trike rides make Everyone smile.
    MN
    3,263
    You said you didn't mess with the mixture screw, does that mean you never removed it? There is a very small passage to and from the mixture screw, the smallest of crud can get in there and mess it up and cause it to run lean, which would cause it to run with the choke on but not otherwise.
    The intake/carb mount can crack and leak which will also cause it to run lean. If you want to know if that is leaking you can test it, or just pull it off and replace it. They can be had fairly cheap online also. You can get a new carb off eBay for the cost of a rebuild kit these days, and its just quicker and easier to swap the carb and be done with it. You will just end up pulling your hair out over the original.
    Don't junk it! If you really decide to give up on it, list it for sale and give it another chance at a second life.
    Jul 2012
    Texas
    21
    Thanks for the positive words, everyone. I just ordered a new carb off of eBay, so we'll see if that helps.
    As for the area that's cracked, it's not the intake boot that goes to the air filter box. It's the other direction--going toward the front of the bike. There's a black brittle section of pipe that connects to the motor. Any idea what it's called so I can try to find it online?
    Thanks again for the help. I'm definitely keeping this sucker until I get it running!
    And I understand about the boiling of the carb--I thought about it, but didn't wan't to ruin my marriage!
    Jul 2012
    Texas
    21
    This is what it looks like: http://www.ebay.com/itm/82-83-84-85-...r#ht_893wt_949. Mine has no black coating around the base, so is in two parts: a black tube that slides around a metal nozzle that attaches to the manifold.
    Think this one would work?
    Jul 2012
    Texas
    21
    OK, so after further research, it appears the part I'm talking about IS the intake manifold. Sorry--I'm new to so much of this.
    MN
    3,263
    Yes, thats the intake manifold, some also list it as carb mount on ebay, but its one of the same. The rubber that is around the outside of the flange peels off all the time with age, doesn't necessarily mean its a leak. If its cracked between the two flanges then you have a problem and likely a leak.
    Want to test it? There is a couple ways. One you can spray carb cleaner around the flanges and on the rubber inbetween, if engine speed changes then its likely it sucked it in and the speed changed. Another way to test is with propane, but you have to be careful. Since you have to pull the carb to replace it anyway, pull the intake off and wash it with soap and water and inspect it, if you find deep cracks in it chances are its leaking, but i haven't replaced one of these yet for leaks, usually its the o-ring between the intake and the carb, or the o-ring between the intake and the engine. Make sure you replace those when you replace the carb, the new carb should come with an o-ring, for the other one between the intake and the engine just take the old one to a local auto parts store so they can match it from their big assortment boxes. Just make sure its a high-temp silicone rubber o-ring so it can take the engine heat.
    Mine still has an occasional hickup at idle, speeding up or slowing down more then the set adjustment, i think i need to pull it back off and replace the o-ring on the engine side of the intake as i replaced the one with the new carb.
