Results 1 to 3 of 3
Thread: hey blue27.. KX80 info needed for the MINI T3.. LOL
    Oswego NY
    1,935
    Hey man, i know at TF you said you had access to dealer info.
    Im looking for whatever you can get me LOL
    The more i get into the mini T3 the more i need to know. I think its a 84 KX80 tank (by the decals), 84 also used alot of holed in the brake brackets, 83 used drum front brake (but looks like tab straight not angled). im just trying to find out what motor parts and what bearings work w what years.
    I found a broken front motor mount on the frame, broken front pipe hanger, blown rear shock and it started leaking oil out of the drain plug area, it has been way modified (i might be ebaying new case 1/2s). And i still have no rear brakes yet LOL
    I did find a works rear shock if i want to spend the cash and i found NEW DG pipes for 84..
    THANKS FOR THE HELP BROTHER!
    MIK6 / Mike
    New England Ride 4/13
    Lancaster, PA
    1,738
    send me the motor numbers and frame number if you can and I will look for info!! I will help as much as I can,lol Might be some NOS stuff laying around also, I will check.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Oswego NY
    1,935
    There is a piece of angle iron welded to the down tube to reinforce it, it was done before they powder coated the frame, might not be easy to get a frame # off it LOL
    Might have to grab motor # and go from there.
    MIK6 / Mike
