Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: 185 s carb ?
    Jun 2012
    Belden, NE, USA
    142
    Quote Originally Posted by atc300r View Post
    Check your carb slide could be in backward.Also check the throttlecable to see if its frayed or pinched some where.
    checked that first
    Jun 2012
    Belden, NE, USA
    142
    Quote Originally Posted by PDADDY View Post
    on my 185s i took a carb off a 200 big red and in starts up first pull
    does it run fast the carb
    Jun 2012
    delaware
    100
    just rebuilt the carb on my 82 185s because it would not idle no matter what adjustments were made, back fired like crazy, and it ran on full choke. bought standard/common rebuilt kit (factory-spec) and replaced everything. the carb is a keihin and the jet sizes are 38 and 100. needle on side, 2 turns out from all the way in. front needle, 1.5 turns from all the way in. top needle(from throttle cable) cliped in 2nd notch from top, and spun that adjustment little over half way out for idle and then had to tweek it out another half turn. this thing purrs like a kitten! found out my throttle cable is stretching when i make a right hand turn and speeds up a bit as if you gave it gas, just rerouted the throttle cable and no more problems. i did have gas pouring out the carb when i hooked tank back up, all i did was hit the throttle and it stopped. must not have been seated correctly. also i never had a front needle in it untill i rebuilt it. all this time the full choke operation, back firing, and lack of idle becase of no needle. don't know if this will help you but that was my experience, and those are the adjustments i made thanks to 3ww and those were the jet #'s stamped on the parts. good luck jeigsk.
    Jun 2012
    Belden, NE, USA
    142
    thank u very help full
    Jun 2012
    Belden, NE, USA
    142
    Hay got the new carb put it on pulled and pulled and pulled and could not get it to start try for like two hour nothing not even a back fire why with the other carb it would start first pull does not make any sense
    Jul 2012
    mississippi
    4
    move the needle jet clip up so the needle can go down further will help with idling. hope this helps
    Springfield Mo
    3,309
    Sounds like your stator is out. I have had the same problem with several 200's and 185's. It will run, but craps out at higher revs.
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Jun 2012
    Belden, NE, USA
    142
    Is it hard to change out
    Jun 2012
    Belden, NE, USA
    142
    The pull rope doses not go all the way in when pull start could that be same problem the decompress cable is not in there right the seal has been tape on could that be it
    Jun 2012
    Belden, NE, USA
    142
    Is there a way to test the stator
    Jun 2012
    Belden, NE, USA
    142
    Would there be no spark if stator was bad
