Results 1 to 11 of 11
Thread: cracked case does it matter?
    86R is offline New to the board Arm chair racerNew to the board
    Oct 2011
    So.IL US
    20
    This is right above the front sprocket does this affect anything performance wise or purely cosmetic?
    Aug 2010
    Southern Oregon Coast
    932
    edited for sake of better pic being posted
    Miami,Fla.(305)
    808
    My motor looks exactly like that (damage on that bolt hole)- it was like that when I bought the motor on EBAY. That was many years ago now. That spot has a long bolt that goes thru to the other side of the motor. This damage is caused by throwing the chain & slamming into the sprocket cover (which that bolt runs thru). I'm sure there is many others runnin with the same damage. No oil/air should come out. Really, the worry is air sucking in - but not from that cracked area rather -its the middle of the case where that long bolt helps squeeze the cases together that you have to worry about.- That being said tho-I dont think you will have any problem - mine hasnt been a problem with that same damage & no bolt. Altho -I split the the case as soon as I got it & put all new bottom end/gaskets. But you should be fine too. Did you just get it or did it just happen?-Anyway, clean it up & do a leak down test to be sure its not an issue. I'd like to see what the others say about this- I'm sure its pretty common. & get a better pic to see it better!
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Oct 2011
    So.IL US
    20
    It was cracked when I bought it. Here's a clearer pic. Its a bit grimy from a fuel leak.
    Big Mike's Avatar
    Hanson, MA
    1,062
    I wouldnt worry about that, if you are ultimately concerned about it you could probably recreate that hold with an epoxy or something like jb weld, redrill the hole and put a bolt in. I have done that before on a similar situation on a sportbike motor once.
    Currently Own:
    1985 ATC 250sx
    1986 ATC 350x
    Projects/Parts machines:
    1980 ATC 185S
    Mar 2005
    overton, PA
    5,257
    find a small diamiter brake tubing and drill the hole out slightly and put itin the hole to the nd of th ebreak and reshape aroudn the proken part out with jb weld if you want to hold the case saver.
    Big Mike's Avatar
    Hanson, MA
    1,062
    Thats a good idea with the brake line brapp, next thought of that one. Good call.
    Currently Own:
    1985 ATC 250sx
    1986 ATC 350x
    1980 ATC 185S
    hogmuffin's Avatar
    hogmuffin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Dallas, TX
    341
    the case is cracked like that on my R. but its the bottom bolt for the chain guard. should have caught it before i bought it, somebody siliconed it all up. it does leak oil. and i'd like to eventually find a new case
    1985 KLT 160
    1985 YTM 200ERN
    1984 YT 60
    Reproduced KLT 160, 110 decals for sale
    Reproduced YTM200ERN decals for sale
    http://www.3wheelerworld.com/album.php?albumid=2655
    Feedback thread: http://www.3wheelerworld.com/showthr...uffin+feedback
    Slidell, LA
    4,738
    That break is merely cosmetic. Although I hate it when that crap happens and I second Brapp's comment. I would HAVE to fix it if it were me.
    MN
    3,263
    I have fixed stuff like that before, it takes a little time but its not too hard. Here is how i do it... Alumiweld rods!
    I have fixed cases and covers, its all in the prep work. Powerwash, degrease it good, wire brush, get the break/crack good and clean. Then a torch and alumiweld rods takes care of it. For a crack i usually fill the crack just above the surface and then work it back down flush and smooth, blend it in, repaint, etc. For a broken off piece like that i would get it good and clean and use a piece of copper pipe for an outside form and a piece of steel rod for an inside form, or you could make it solid and drill and retap it too depending on how you need it, but basically you recast the missing piece with alumiweld rods and then rework it. The key is to get it good and clean and rough up the surface so that you get good adhesion. It works!
    I never have had any luck with stuff like JB Weld, that crap always falls off in a week or two.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Mar 2005
    overton, PA
    5,257
    yes a piece of copper rod solid preferably inside and tig aluminum rod around the broken area and build it back up, the aluminum will not sticlk to the copper rod very easily. but a steep brake line boss is the easiest way.
