WHAT DO YOU ALL THINK OF THIS IT'S ONLY A COUPLE HOURS FROM ME AND I'M THINKING OF GOING AND GETTING IT...$1600.00 WORTGH IT??
1985/86 Honda 250R ATC FOR AUCTION this complete Honda 250r liquid cooled ATC. The reason I’m calling it an 85/86 is because it has an 85 Swing arm assembly and an 86 carb. The frame has been powder coated Honda red, and had the swing arm coated silver vain. I have either polished, powder coated, painted, or zinc coated every item in this machine. It is very, very clean, it has never seen the dirt at all. This is one of the nicest ATC’s I’ve ever seen. And probably one of the fastest with a stock type cylinder. Here is a list of most of the things is has. Newly power coated frame and swing arm, New axle bearings, New seat cover, New DG aluminum rear grab bar, Nearly new tires, Top end has less that 10 hrs on it, Ported and polished cylinder, FMF Pipe and FMF polished silencer 1986 34mm Kein PJ carb, Low profile aluminum handlebars, Prodesign Kill switch, Unifilter with K&N pre charger, MSR-EZ pull clutch lever, . Machine comes with clear title card and a signed receipt from me. Wheeler is sold as is.
