Wow, that's the first one I've seen go that way! You MAY be able to pull back evenly on the forks with two come alongs on both sides of the frame but not sure how successful that would be.I'm thinking you're going to have to disassemble everything, flip it over and get it into a press. Hopefully one of the experienced 70 guys will chime in. Good luck.
Trikes
1970/71 US 90 (Aquarius Blue)
1972/73 US 90 Green
1982 ATC 70
1983 ATC 70 (Ladybug)
1973 ATC 70
TF 2015
Other
1983 Honda Z50
is it a jumping trike? and how much do you weigh? Not to be intruding, but they could bend if you take flight with it and weigh over a said amount of weight
We actually bought it that way.
if you brace it, i say put the brace along the top like murf did on his. maybe grind the ends down a bit to match the curve of the frame if your not going to straighten it.
murf's project thread, http://www.3wheelerworld.com/showthr...new-70-project
That's a good idea! Thanks!
