I've had a ongoing issue with the axle retainer clip located right of brake disk. It kept popping out of place as I applied pressure from adjusting nut. I thought I had it, I thought wrong. Axle slipped by, threw chain, toataly ripped shifter off and busted a case saver bolt. Made me sad is a under statement. I've solved the problem by making enough room for the clip to fit slightly under the disk hub. Surely it can't get off now! The damaged case fix will need attention. Who knows when.![]()
