Boring the cylinder and installing a new piston will not increase the compression much at all, maybe a few psi if your lucky. There is no high compression piston on this 2 stroke. The way compression is increased is by modifying the head, which is shaving the head, or removing material to make the combustion chamber inside the head smaller. You could do a squish test (do a search, there are several) and see what you get, to be sure the head work is safe, and not a hack job. You can always get the combustion chamber re-cut, to correct the compression, or install a stock head. I hope this helps...
81, 85 Yamaha Tri Moto 125
83 Yamaha Tri Moto 200 x2
85 Yamaha Tri Z 250
84 Kawasaki Tecate 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
(2) 84 Honda ATC 200x
82, 83 Honda ATC 185s
81 ATC 200
Lots of other parts and bikes
