Results 1 to 10 of 10
Thread: could the stator be the problem 185s honda
    Jun 2012
    Belden, NE, USA
    142
    bought new carb old was wrong carb it would start first pull but could not get it to idle down. put on new carb will not start. pull rope and cable for decompression cable r mess up some has open it before tried to get the flywheel off nut would not move it also 100 degress outside did not try to hard
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    334
    How did you try to get the flywheel off? Did you use a flywheel puller tool?
    Jun 2012
    Belden, NE, USA
    142
    I got it going . Thx though
    Jul 2012
    Douglas, Ma.
    124
    what was the culprit?
    Jun 2012
    Belden, NE, USA
    142
    Loose wire by carb
    Mar 2007
    tx
    109
    Thats why u always do a visual inspection...
    Jun 2012
    Belden, NE, USA
    142
    Quote Originally Posted by tx200m View Post
    Thx tx. it was in a wiring boot
    Jun 2012
    Belden, NE, USA
    142
    It called a pulley puller. Yes would used one if needed. I could not get the nut bust loose but do not need worry it running.
    MN
    3,263
    Its always something like that it seems, one stupid connection that takes time to find. Glad to hear its running!
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Aug 2012
    Galax , Virginia, USA
    It a honda flywheel puller. its doent work on anything else.
