If i remember right i heard that you could use different hubs off of something else so you can use 1/110mm bolt pattern on a tri-z. Which hubs will fit on a stock axle?
85 Tri-z
38mm Flatslide
Boysen Power Reeds
DG Pipe and Silencer
Bored 1.25mm over
Wiesco Pistion and Rings
K&N Clamp on Filter
Compleating Restoration
Banshee, raptor and blaster hubs fit the axle.
The blaster wheels are the same bolt pattern and size.
I put banshee hubs and wheels on my Z
SEND ME PM HERE - CLICK HERE
Dirtbikes:
1988 Yamaha DT
the blaster hubs are the same 1/100mm bolt pattern? or are they 1/110mm? also what year of the banshee, blaster and rapter fit?
85 Tri-z
38mm Flatslide
Boysen Power Reeds
Bored 1.25mm over
K&N Clamp on Filter
Blaster is 4/100, Banshee is 4/115 except 89-90 is 4/156. To go to 4/110 you can use the 200x and a half dozen other Honda ones, such as this one http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2444495352&category=43 972 (like the way I plug my sales?)
They do fit a little tight, and you might have trouble putting them on a brand new axle, but Ive never seen a used axle they wouldnt fit on.
do you have an idea on which modle hondas fit, Do the 250r ones fit?
85 Tri-z
38mm Flatslide
Boysen Power Reeds
Bored 1.25mm over
K&N Clamp on Filter
