Results 1 to 15 of 22
Thread: What rims for 185 s
    Jun 2012
    Belden, NE, USA
    142
    What rims for 185 s
    What rims will work if have a 1980 185 s Honda. Make and years
    Jun 2012
    Belden, NE, USA
    142
    No ones wants to help
    6,811
    Its an odd ball size 4x155mm I believe so stock is best unless you change the rear hubs to a atc200x and use the common 4x110mm and the rim choice is simple and vast LOL .
    4x4van's Avatar
    4x4van is offline At The Back Of The Pack Arm chair racerFirst time rider
    SoCal
    160
    Quote Originally Posted by jeigsk View Post
    Correct...no one wants to help since your other post had such terrible spelling, grammer, punctuation...and then you bad-mouthed those who were trying ro help, even though they couldn't understand anything you were saying.
    You get what you give.
    Those who can ride, ride...those who can't, drive.
    Jun 2009
    Leander TX
    2,217
    I bet you don't have a 1980 185s...
    Assuming it's the big tire 185, it came with 9" diameter rims with a 4x150 bolt pattern. So, check out this chart for other 4x150 ATVs:
    http://www.pureoffroad.com/ATV_Wheel...tern_Guide.htm
    Other options are to change your rear hubs like Shortline said - hubs from nearly every other Honda ATV ever made bolt on except 85+ 250R and 85+350x. But, you're stuck with the front hub.
    Jun 2012
    Belden, NE, USA
    142
    Quote Originally Posted by 4x4van View Post
    No no no they start. There no reason to be mean.they started first. I was looking for help and wanted to be smart a s s
    no no they started it. There is no reason to be rude. If u do not understand then keep
    mouth shut. That is way nicer then being big as hole. right
    Jun 2012
    Belden, NE, USA
    142
    Quote Originally Posted by jb2wheels View Post
    it three bolt and has same tire size as my
    200 x
    Jun 2012
    Belden, NE, USA
    142
    Rear hub I think might be wrong. The rim was split. It like dbl rim or something. In can touch the tube in side rim. But it air up . Have seen a rim like this.
    Jun 2012
    Belden, NE, USA
    142
    Rear hub I think might be wrong. The rim was split. It like dbl rim or something. In can touch the tube in side rim. But it air up . Have seen a rim like this. Ok. The bolt wher the wrong size. It was not bolt straight. But have two 185 so toke the one off it tell can get new hub at least.
    Jun 2009
    Leander TX
    2,217
    Oh - interesting.
    81 185s came with 3 bolt hubs and split rims. 3x100 bolt pattern like most Hondas up to that point. Either way, the 3 bolt hubs bolt right on the axle.
    The rest of the answer is still the same. Without changing hubs, you're looking at ATC70,90,110,185s,FL250 and Maybe Tri-Moto and one or two old Suzukis.
    Jun 2012
    Belden, NE, USA
    142
    Oh - interesting.
    not sure the year can not find tag on it. So u r saying.the hub should not permanent bolt but u just put bolt in and out
    Maine
    463
    I just picked up a 1982 185 a few days ago. I'll take a look at the rims tomorrow.
    Current Trikes
    2 1985 Honda 250sx
    1985 Big Red
    2 1983 YTM 200k's. 1 for parts.
    KLT 250 Prairie
    1982 Honda 185 - Waiting to be saved
    1985 125m Parts Machine
    Still on the hunt for a 1986 350x and 250r.
    Jan 2011
    Brazil, Indiana
    2,087
    I hate to rub it in, but I told him this was going to happen. LOL
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Jun 2012
    Belden, NE, USA
    142
    Quote Originally Posted by hoosierlogger View Post
    What did tell me. You told me to get a tape measure
    Jun 2012
    Belden, NE, USA
    142
    Quote Originally Posted by Keepah Rolln View Post
    sorry about this other people are messing up this forum. They like to do that . Thank you for some real help.
