IM so glad I found this forum its helped me so much thus far, enough that I've decided to join. So first post with a big hello to its members.
So let me start off by saying I bought my son a 4 zinger, it ran like utter crap. But did run. Brought it home cleaned the carb changed the reeds to boyesen still nothing. Bought a compression checker 60psi, Tore off the top end and its junk worn worse than a brake rotor. So I then found a guy on craigslist selling two red tri zingers with motors rear axles etc for 200$ can never have enough extra parts. However both cylinders were not up to snuff so I ordered a whole new cylinder set off ebay to fix the top end issues, hopefully. I also ordered a new spark plug system. I dont have the tools to check the autolube so thats going to have to be disconnected for now and run 32:1 premix.
So now Im waiting for the top end to come in and Im thinking while the engine is pulled what else I should replace. Im concerned about the crank case seals and if those should be replaced now or see if its leaking once the top end is on and engine is running. Ive never tore an engine down before and man this has been a lot of fun learning about the engines with my 5 year old. For a dad this is great experience, but I really want a running engine with my son you know go for the win!
Anyways, It seems the engines I've cleaned up thus far all seem to have WELL over the amount of fluids in the clutch area like double the amount. Which seems to tell me the crank seal is gone the fluid is dark with a slight white milky look. Do i really need more tools to replace these (aka fly wheel puller) Do I have to split the cases to swap them out? Will I hurt the engine and new top end if the seals are leaking? I know I should probably just split the cases and do the whole thing, but this project has been you touch it and it breaks what do you expect from a 30 year old machine. If it aint broke dont fix it!
Is there any way to replace the rear gear fuild in the axle without removing the special bolts?
and a stupid question, which side of the gasket goes on the crankcase the rubber or paper side? I would assume the rubber as yamabond would adhere to the paper.
when I had one engine running the carb was leaking really bad too I cleaned them and cleaned them again replace the valve nope. Seems to be coming from the drain plug. Next would be a new float that has checked out with the submerge test.
And finally I have LOTS of tri zinger parts if people are in need of anything. Frames forks fenders fairings, wheels tons of parts some in ok condition some look darn brand new. I have a fiberglass front fender as well all for sale along with engine components I dont need 4 engines, LOL.
Trikes Currently Owned:
