Results 1 to 15 of 21
Thread: How Much to Reassemble a Motor?
    Popeye is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2011
    MS
    301
    I'm about to have my 81 ATC 200 finished (not restored- just complete and running great) and am getting ready to start back up on my 84 250r. I've got 300 head that I will get taken care of locally, but the bottom end is basically no go good other than the casings. I'm working on acquiring all of the motor parts. How much would somebody charge to put the bottom end together for me? The local shop (the only one that will touch a trike) quoted me at like $70 an hour and said it will take at least 8-10 hours, maybe more. That's around $700 plus. I could buy a running motor for less than that. Is that aboutthe going rate for this job or can some of ya'll folks do it cheaper? I realize shipping may be a problem. I'm gonna check into that. Hoping for a flat rate box, but I ain't counting on it. I've got to explore my options on that. Anyways, just trying to get an idea of what this will cost.
    Thanks for any input.
    NEPA
    7,051
    Disassembling,cleaning,evaluating and reassembling a R bottom= about 5 hours. A good tech will run ya $45-$70,,but those guys are ripping people off,unless they saw yours and it's cobbled up w american bolts etc.. Hard to say without pics. You say all but the cases are bad? If you need a tranny,,or even all bearings and seals for that matter. I'd look for a good low end. I have a cpl I think. Shipping is costly though.
    Oct 2011
    MS
    301
    Yea, I think the casings are about all mine may be good for. I'm in the process of tearing it down now. Haven't broken it open yet. I thinkthe bolt that holds the clutch basket on is stripped. What is the typical socket size? I tried a 1-1/16, everything else is either too big or too small. I think the manual says a 27mm if I read it right. But that don't make sense to me, cuz this 1-1/16 fit then stripped it out I think. If I could just get that basket off then I could inspect the tranny. The motor is full of sludge (it comes up with the rod). It sat outside with no side casings, but the head was on it. I was thinking I could get it apart and then soak everything and then see what I got.
    ATC007- I am sending you a PM.
    Scootertrash's Avatar
    In the sticks
    4,638
    The stealerships up here in MN are running at 90-95 an hour for labor. My machine shop guy charges 250.00 for bottom end labor (his shop rate is 75.00/hr), then you'd have to throw parts into that. My rate is a little cheaper than that, but I have machines stacked up like cord wood to work on so I have no time. The situation you have there, well, ya never know what you're going to find once you get her cleaned up.
    Oct 2011
    MS
    301
    Yea, I was thinking soak everything in oil or something and then post pics of all the gears and what not to get opinions on what is good and what ain't. I'm probably in the market for a bottom-end, but it will be a bit before I can get it. I would love to hear from folks who have one. I'd prefer a bolt on ready one, but I'd be interested in anything. If I can get one cheap I might be alright between the two I would have.
    Quote Originally Posted by atc007 View Post
    Bill, you know I luv ya!! But thats like 10 to 15$ an hour. Maybe there are some good techs at that cost but I won't lift a finger unless I'm in the 25-35$ an hour. I'm too particular, it's taken me years to learn these motors and I still by no means consider myself an "expert". I just do the best I can....
    But, I do my best and warranty everything unless they have a jetting issue....
    Oct 2011
    MS
    301
    I took it as $45-$70 an hour. But I'm usually wrong when it comes to just about everything lol.
    Quote Originally Posted by Popeye View Post
    Nope, your right. Any dealer will charge you those rates. Some garage guys can do as well or better a job than a dealer and save you some bucks.
    Columbia
    5,131
    I used to charge around $100 to go through a smoker bottom end. Thats probably also why we went out of business lol. And that was also OUT of the frame.
    NEPA
    7,051
    Ohh,same here,, I am absolutely anal. But<if I can't go flat rate,I'm not doing my job. : ) Obviously,not everyone should be held to those standards. But I hold my self to flat rate. if Billy Bobs doing it for a case of beer. You MAY get a perfect job! BUT,,,,,,You MAY not.......lol.. WHich always ends up costing more in the long run than it would have cost up front.. But I Totally here you DC. It's just because I'm a shop. Same as your machine work! I know that is top notch!
    Kentucky
    511
    Download a manual for free and do the work yourself. It's not rocket surgery. If you want something done right do it yourself and save alot of money. Anytime I ever paid anyone else to do a job I seen I could do it just as well or even better than they did with the exception of port work. They are just doing it for the money and are going to do it the fastest and cheapest way to get you out the door and your money in there pockets. Alot of the stuff that I work on I couldn't afford to pay a person the time it takes to do it. You will be amazed how easy it is and if it ever have problems you won't be intiminated to tear into it and fix it.
    NEPA
    7,051
    Quote Originally Posted by stroberts22 View Post
    While I agree .. And would love to see everyone try.. A Ruined crankshaft , water pump,etc..because the thread was left hand. Won't shift because the forks aren't in right. Or because the pawls are in backwards.. The things that can and do go wrong,COST,,Time and money.. There is great satisfaction in doing it yourself ,,sure,,it's the American way,,well used to be.. But I have seen TENS of thousands of dollars parts ruined over the years by do it yourselfers,,JMHO>
    Oct 2011
    MS
    301
    I agree with what your saying, but I also know enough to know that I'm not ready to build a motor from the ground up. I've put in clutches, rebuilt top-ends, and done a few other minor jobs, but I just don't have the confidence yet. If I could watch it done a time or two I have no doubt I could do it well enough. With all that said- I've never touched a 2-stroke. Heard they were simpler, but I'm just not ready yet.
    Southern MN
    1,875
    Those old air cooled motors are about the easiest to work on. I agree with most of the above, get a service manual, and follow the steps, and dont skip a step. I went to college for powersports, and this is what I learned. As long as you follow the guidelineds (especially if its your first time) you will have no worries, I promise. I have torn a few apart before, and brought them to a shop to have the new crank bearings and crank installed, and it was 30 dollars each time, and have not yet had an issue. Most all the other bearings will come out easily, so whatever you can do yourself the better. Dont bring the whole motor to a shop, you'll get ripped off. I have worked at several shops, and know how it is. If you want to ride a 3 wheeler, you got to know how to turn a wrench, no questions asked. I would start by getting the correct socket - 27mm you say, NOT STANDARD, and use an impact wrench for that clutch nut - and no other nut besides flywheel on this motor. If you have questions, take a few pics, and the boys and I here will definatly help you along the way.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Lewiston, N.Y.
    1,477
    Hey man, I just did my clutch on my 250sx and mind you i have never torn into a trike motor before. I was a little nervous but honestly, I followed the manual step by step and everything turned out right. There were a few parts i was a little unsure of but i just sat down and reread the manual and it eventually made sense. It def looked intimidating but once you get going it honestly isnt that bad at all.
