Results 1 to 15 of 52
Thread: Project 185 - old school racer
    New Brunswick, Canada
    60
    Ever since since flipping through a 1982 issue of DirtWheels and looking at the pictures of Curtis Sparks and Tommy Gaian Tearing up the track on Team Honda's 200's I knew i had to build something like that. The old school 200's just look so bad ass. I then read through an article of the installation of a PK suspension kit on atc 185 collecting ideas. I did lots of research and parts collecting and reading through others builds on suspending a hardtail trike. I finally started my project a few weeks ago and have been taking lots of pictures. So here's my progress.
    Pile of parts
    The donor
    60
    Stripping the donor, at first i planned to use the swing arm from the dirt bike and modify it to accept the trike rear end but decided against it because it would take far too much work to make it work, and i would just end up with a cobbled up swingarm. So I fabricated the swinger from scratch.
    [IMG][/IMG]
    NEPA
    7,051
    I have a good feeling about this one : )
    60
    Junk engine i threw in for mock-up purposes, mainly sprocket alignment.
    Brace I had to add
    Forks From the CR i will use, Planning on fabbing my own triples from some DOM
    Fabbing the swinger. I cut the pivot ends off the CR swinger to use for the new one.
    Plates welded on.
    Gusset Templates
    Gussets all welded
    Axle and rear end mounted
    Nov 2007
    Good looking welds. Keep us posted on your progress.
    Chris
    OK
    5,450
    Looking good.... Love to see a good weld...
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    60
    Pivot end full welded, still needs some smoothing out
    some pics of stripping the 185 frame. I should have put them in earlier.
    Template for the swing arm mount
    Plate Tacked in
    then full welded and trimmed
    I should have drilled the holes for the swinger bolt into the plates before mounting them so I knew they were the same. Oh well, learn from your mistakes.
    Mocking up the swingarm
    zeeker1's Avatar
    zeeker1 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Canton Ohio
    184
    Looking great. I love a good fabricator. Here's some pix of some PK parts that they used for there 185S bolt on. I still have mine so if you need anymore, just ask..........zeeker
ID:	151112Click image for larger version.
ID:	151113Click image for larger version.
ID:	151114Click image for larger version.
ID:	151115Click image for larger version.
ID:	151116Click image for larger version.
ID:	151117Click image for larger version.
ID:	151118Click image for larger version.
Name:	Honda rear suspension 001.jpg
ID:	151119Click image for larger version.
Name:	Honda rear suspension 010.jpg
    zeeker1's Avatar
    Canton Ohio
    184
    Here's a couple more of my spare...........Just for ideas.
ID:	151122Click image for larger version.
ID:	151121Click image for larger version.
ID:	151123Click image for larger version.
    Slidell, LA
    4,738
    Great work! You weld for a living? Your welds look like a roll of nickles.....love it!
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    fyi.. it looks like your swinger pivot will be approx 2inches further back than a pk kit,,,, which is ok if you get the position of the bolt perfect,, if not i think the chain will tighten and slack off as the suspension works and sense you are back more then it will be amplified
    Nov 2004
    Waterloo IL
    2,701
    I love it already. I have a suspended 185 project myself.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    60
    Haha thanks, I'm actually an apprentice truck mechanic, but I started playing with welding when i was 12. So I've got about 6 years of practice.
    60
    Thanks for the pics zeeker. It gave me a good idea for a chain tensioner. I'll have to copy it.
    60
    I was thinking about that a lot, the chain tightening under compression or droop. But my swingarm bolt looks almost in the same spot as a PK weld on kit, I tried to copy it from a magazine. But i figure it will be a lot of trial and error involved. I just snapped some pics out of the magazine article and will post them when my camera battery charges, in the meantime here is the swinger hanging from the bike
