Results 1 to 11 of 11
Thread: how to remove anidization?
    Feb 2003
    wisconsin
    64
    I am rebuilding a Big Red and am wondering if there is a quick easy home remedy to remove any of the anidization on a alum. motor?
    Mar 2003
    Australia
    1,919
    What type of bigred??
    If you mean the anodizing on the engine cases, i would get some paint stripper and some steel wool and get stuck into it. It would need polishing when done though cause the steel wool will leave scratches in the casting.
    Hope this works for ya.
    BTW where is the anodizing on the bigred............
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Feb 2003
    wisconsin
    64
    big red rebuild
    I am lookin at removing the anidization on the valve cover, head, cylinder, ect. I was wondering is a HCl/H2SO4 acid soak or something like that would work. (homeremedy example: toothpaste works as a silver polish). I guess I am stuck with old fasion "work". Oh well...it is worth it when it is done.
    Ithaca, NY
    2,596
    DONT USE STEEL WOOL TO POLISH ALUMINUM!! dissimilar metals dont mix. There is a product referred to as "non woven" abraisives, kind of like the green pads your moms warshes dishes with. For polishing aluminum, steel and stainless, you need either a 3m "scotchbrite" or Norton "beartex". SIA also makes it, and its alot cheaper. There are 4 or five color hand pads, each is the different "grit". use maroon, and then white to finish. This is how its done. get it at an industrial supply, or my brother said he found some at lowes or home depot.
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
    Fresno Ca
    2,695
    anidizing is the 2ed hardest thing on earth (behind dimond) so have fun removing it.
    Nov 2001
    B.C.
    933
    Use Easy-Off to remove ANODIZING.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Ithaca, NY
    2,596
    are we talking about OXIDATION or ANODIZING?? with the wacky spelling by some of our beloved members, its hard to tell sometimes!
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    I think they mean oxidation, anidized stuff is parts that you get that have that red, blue, or whatever chrome look to them. A good homeremdy to use when you want to polish something up is to use cola, and a steel wool brush (I think), but seriously, regular cola will shine the hell outta about anything, especially chrome.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Apr 2003
    141
    remove
    i used 99 cent oven cleaner w/ the fumes. thats what i heard anyways that it has to have the fumes. well anyways, i used it on my rim on my z and it came out great. spray it on, let it sit for a couple of minutes then rinse it off and then use a scrubby brush or something, not metal, i used a sponge, and scrub the stuff off. some anodizing may be more stubborn than others but it worked excellent for me, then i used polishing compound and they came out awesome. good luck, just be sure to not leave it on for more than say 3 or 4 minutes.
    Leaks, Leaks, Leaks! Why does it always have to leak!http://www.3wheelerworldforums.com/viewtopic.php?t=11559
    junjun01 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    290
    Quote Originally Posted by Trikeaholic
    Sometimes I Wonder...Sometimes i Have To Guees What Some People Write Here Too !! :-D ....Don't B Offended..,I Mean Nobody In Particulaer
    Aug 2003
    290
    Oops!!...I Did It Too :oops:
