questions about engine coatings
Im about to send my frame and swingarm out to get powdercoated. I was thinking about getting my engine powdercoated as well. Has anyone had any good or bad results from high heat p.c.? I don't really want to paint it.
the only problem I see with powdering an engine is that it has to be completly torn down
PJ1 epoxy engine case paint,,,, gloss or satin.... the best!
I already tore my engine apart because i had to rebuild the bottom end.
if you are Powder Coating, you gotta ensure that all of the old paint is removed and the surface is spotless. I prefer 120 glass bead or you can use soda, or if you have a lot of time you can hand sand. I would probably by new bearings if you are going to use glass bead or soda. Other than that, make sure you are using a heat resistant powder....any powder guy worth his salt would be able to prep the cases and coat them for you.
Feedback for yaegerb:
Click Here
//ArrowChat Integreation Code
