I have a couple questions about mounting a Warrior shock on a Tri Z:
1) I noticed that there is no compression adjument knob on the resevoir....is the shock still better than the Tri Z OEM?
2) How do you make it fit in the frame bracket. The Tri Z has a loop on the bottom of the mounting bracket...the warrior shock has a the hose coming out from the bottom of the resevoir...??? It wont fit?
Thanks...
