Results 1 to 7 of 7
Thread: Will this kit work with the atc 70????
    Oct 2011
    orangeville ontario canada
    32
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    yes it will..
    Nov 2004
    Waterloo IL
    2,701
    I like how it says it's a genuine Lifan not a knock off. LOL!
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Jan 2011
    Avon, Minnesota
    641
    Quote Originally Posted by Blown 331 View Post
    i saw on a website once before for a ring it said Genuine cubic zirconia....
    1983 honda 200x 185 motor, Uni air filter, bassani exhaust, itp rims. FOR SALE!!!
    1982 honda 200 bigred cobra exhaust
    1989 yamaha banshee fmf gold pipes boost bottle k&n airfilter
    Jun 2009
    Leander TX
    2,217
    Define "work with the atc 70".
    You'll have normal issues with a China clone swap:
    - The engine will bolt in and the chain lines up
    - How will you start it? Use the kicker that kicks to the rear or adapt a pull starter or just bump start it?
    - If you pull start it, will you be able to hold the clutch in while you pull it or just shift to neutral every time?
    - Carb mounting and clearance
    - Will the stock throttle work or do you need a different one?
    - Clutch cable
    - Footpeg mounting/clearance
    - What exhaust will you use?
    - How will you wire it up?
    No real show stoppers and they've all been dealt with before.
    I'm working through some of them now on a TRX70 swap with a slightly different engine (125cc, e-start, semi-auto 3sp+rev).
    Good luck and have fun!
    Oct 2011
    32
    Thanks. As long as I don't have to stretch the frame I'll be alright.
    -Ive heard the kick start will still start the bike it just hits the tire if not I'll just bump start it
    -carb clearance shouldn't be a problem I got the replacement gas tank from hondaatc70.com whitch gives you more clearance
    -not sure about my stock throttle
    -gonna have to get a clutch cable whitch means taking out my hand brake I geuss, anyone know clutch cable size?
    - not sure about stock footpeg mounting
    - getting exhaust from hondaatc70.com
    - wiring comes with the engine kit but not sure how to wire it up either.
    Oct 2011
    32
    I'll probly just get a new throttle cable nd killswitch wat about sprocket sizes nd chain size?
