hey guys i need the swing arm collars for a first gen 250r and and cant find any does anyone know of something else that fits in there maybe from another model bike or a mod that anyone knows of
I had to have a machine shop make one for my 82 250r. If your interested, i can find the dimensions for you. let me know.
yea that would be great if you could do that
O.D.= 20mm
I.D.= 15.10mm
Length= 68.25mm
The dimensions were taken from a NOS collar (52141-961-000) for an 82 250r. After the heat treating, the I.D. was a bit too small. I took it back with my swingarm bolt, and they machined it out a bit and has worked fine for 6 years.
Hope this helps,
Marc
82 250R: If you don't mind my asking, what did they do for heat treating?
i would do some checking and see if a 1982 CR 250R swingarm bushings are the same dimensions or part numbers as a 1982 250R. If so, I have pasted a link to a rebuild kit below on ebay....
http://www.ebay.com/itm/Swing-Arm-Be...458769&vxp=mtr
HRE can make you any swingarm to use any carrier, such as a 450R carrier and caliper.
If you haven't read anything on him, Google him.
Not cheap but if people cave have a CLUE as to what this stuff takes, they don't mind paying. Can't hurt to look him up.......
82 250R: so about how much did getting those pieces made cost you
have anyone tried just cutting a 200x collar into pieces and seeing if that works
I know heat treating can change the size of a part sometimes. I was wondering if maybe they just did a case hardening type of heat treat that just hardens the outer surfaces of the part.
Slaughter; This isn't an offer just yet, but I just got some swing arm parts from another member and I am going to try to make a set of swing arm bushings out of Delrin that will eliminate the sleeves/collars you are talking about. I have a lot of irons in the fire right now so I don't want to offer something I can't finish.
Let me see if I can do these other bushings before I try to help you out. If you find something else in the meantime so be it. I just don't want to make a commitment I can't keep.![]()
Scootertrash : that would be cool if you could do that
i know there is a guy over ats that is trying to get a group buy together for teflon bushing sets but sometimes it does take along time to get enough people together and the price may still be a bit of an isue
but in the meantime i think im going to try something with the 200x collar (i just cant see myself paying that much money for a little piece of metal)
Stuff I Have Or Had
85 ATC70 - stolen
85 ATC110 - Stolen
83 ATC110 - Gave It Away
86 ATC125m -Gone
83 ATC185S -Gone
?? ATC200 Big Red-Gone
83 ATC200 -Gone
85,85,83 ATC200X - Gone
84 ATC250R - Running but needs 2nd gear
83 ATC250R -Gone
84 ATC200M - Freebie
85 ATC250SX - The Barny Trike It Rides Now
85 ATC250SX - Gone
85 ATC350X - My ride for now
86 ATC350X - My son rides this one now
99 FXSTS - My Baby
08 SunL 150cc Dune Buggy - For The Little Guys
x.systems last post on this site was 5/29.
That's why I am going to try to make a set for the other member. I'm pretty confident I can do it.
Problem is, a lot of members of online forums don't have faith in someone trying something they haven't done before, I've seen it many times.
I made these bushings for a '91 Polaris 350L I completely rebuilt. Motor was rebuilt, tranny was gone thru, every bearing, bushing and wear part was disassembled, inspected, repaired/replaced and got fresh lube. EVERYTHING.
Here are some bushings I made for that machine. The metal ones are similar to the construction of the 250R bushings. A metal sleeve or collar that the swing arm bolt passes thru. The metal sleeve passes thru a phonelic/composite bushing/bearing that is a tight slip fit into the swing arm.
The plastic bushings are for the rear shock. The old ones were shot, as you can see, and no one sells anything that fits as a replacement, so I made 4. Two for the top shock mount and two for the bottom.
This is a chain roller I made. Once again the replacement part is discontinued. This roller fits over the swing arm mount bolt and nut to protect the swing arm bolt and nut from chain slap.
Do I have the skill to pull it off? I think I do. Will I be able to meet the anal retentive standards I set when doing something for someone else? More than likely. Will I be able to do it in a timely manner so it's worth my time to make this one set, let alone more if others want them? I(we) shalll see..........
