Results 1 to 15 of 23
Thread: back breaks stuck!
    snohomish
    51
    back breaks stuck!
    Okay so i believe i got a 185s, there is a tag on the body, or i am looking in the wrong spot. when you push the bake break to the point it cant go farther and the break is full in, it doesnt want to come back, the back break i believe is stuck and thats why it wont roll.
    how do i either disengage or take off the bake break till i get a new cable?
    Go to the actuation arm. That's the arm on the rear end that the cable attaches to and actually makes the brake work. Pull that arm back until the brake releases.
    Are you sure the cable is the problem?
    snohomish
    51
    im not 100% sure the cable is the problem, whats the bets way to troubleshoot this?
    Take it apart and clean and inspect everything. Lube the cable, the brake actuation cam, and the lever. Replace worn brake shoes and inspect/replace axle bearings and seals while you're there.
    First thing to remember, these are 25+ year old machines.
    snohomish
    51
    i fixed it not sure what this part is called, but it was jammed and pulled back all the way,
    the person i bought this from has some tow hit thats on wrong and its pressing on the brake. but i got it fixed.
    snohomish
    51
    also my axel s a bit loose so do i just tighten the bolts on each side of it?
    It depends on where it's loose. I'm not trying to make you feel stupid, but I can tell you're not terribly well versed in the science of trike repair. Find out where it's loose and then we can tell you what to do. If it's loose in the middle, i.e. the trike rocks side to side, you'll need new axle bearings. There is no way to take the slack out of them. When they wear out, you just replace them.
    snohomish
    51
    the part i have highlighted in red, the middle part if you rock it back and forth it makes a noise when it moves it slides a bit back and forth
    and i know this is my second trike i only had a 110 before now a 185 or a 200, and the 110 didnt have alot of problems. once i tighten this back axle or buy a new bearing the thing is solid
    If it's sliding back and forth (laterally) then there is a chance you can just tighten the axle nuts and be good to go. If you snug the axle nuts up and have a side to side "rocking" motion, then you need new axle bearings.
    The two nuts on the right side of your picture hold the axle in secure. It is a "lock nut" setup. You back the outside one off a bit and then snug the inside one up so there is no lateral movement in the axle. Once you have it snug, tighten the outside nut back into the inside one to hold the two secure.
    Just remove both cables and see if the brakes work.
    One of your cables may or may not be correct. I have had good luck with silicone spray on cables mounted in my vice and the moved up and down while spraying them.
    Then pull the brakes apart and clean/lune inside there.
    If you can get some new cables, the do so.
    Honda pads are made with Elmers Glue. Once they get wet, they fall apart.
    snohomish
    51
    its just the lock nuts. the bearings are fine
    snohomish
    51
    i am going to order new bearings just so thats one less thing i have to worrie about.
    is this the kind of bearings im looking for?
    http://www.ebay.com/itm/Honda-Atc-18...item51952f4b9f
    They are, but you get what you pay for.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Yep, those are the bearings and seals you need. From memory here: 6007-2rs ( bearing ) and OS-1503 ( seal ) need 2 of each.
    Howdy
    snohomish
    51
    thanks guys. i am going threw the internet and all the ones i see are like 17-20$ nothing more high duty
