Results 1 to 3 of 3
Thread: honda 250 sx broke bolts in oil filter housing can it be fixed?
    Jul 2012
    utica ny
    29
    can it be tapped?
    goump1995's Avatar
    goump1995 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Louisiana
    167
    Oh gosh, I know what you're going through. Pissed me off so much. Broke the tip off of my Snap-on 3/8 drive Phillips screw driver head socket. I was using that and my Snap-on Impact (You hit the end of the impact so many times with a and it turns it, never failed on me until then.) What I did was drill out the screw heads with a drill bit one size bigger than the screws themselves, then tapped out the screws. Didn't damage the part at all. When I put it back together I installed 8mm hex sockets to make it much easier next time. Good luck
    -Travis
    My Trikes:
    1981 Honda ATC250R
    1982 Honda ATC 200
    1984 Honda ATC 200S
    1984 Honda ATC Auto 200X
    1985 Honda ATC 200X (Basket case)
    Howdy's Avatar
    Celina, Ohio
    10,079
    Yes, you can remove the broken bolts and or fix the threads. It might be cheaper / quicker to get a different side cover though. I have at least 2-3 of them I would sell for $10 each plus shipping ( $8.50 via priority mail ).
    Howdy
