Thread: Transferrable parts from 200M engine to 200E engine
    Jul 2012
    Manitoba
    5
    Hi All
    I have a 1983 Big Red 200E that apparently has an engine knock. I say apparently as I haven't heard it run, but purchased it from a friend for $120. I have a Honda 200M engine that is waiting to be used.
    Question 1: Can I use parts from inside the 200M to possibly rebuild the 200E engine?
    Question 2: Would it be better to just swap the 200E engine out directly for the 200M engine?
    The original engine on the Big Red has high/low range plus reverse, so obviously if I can rebuild the old engine with the 200M parts, it would be a better end result for usage.
    Thanks!
    Frenchy
    Howdy's Avatar
    Celina, Ohio
    10,079
    A lot of different things to think about here:
    If you have a 83 200e ( chain drive ) and it has reverse you have a add on kit for the reverse ( fairly rare ).
    If you have a 83 200e ( chain drive ) then the 200m motor should bolt right in.
    If the hi/Lo/Reverse is factory then you have a shaft drive ( 84 model only ). The 84 200ES Big Red was the only Honda 200cc model with reverse and shaft drive. These were only made 1 year.
    Either way If the knock is in the rod, piston or vavles:
    The complete top end will swap over and I'm 80% sure the crank will swap over as well. Those items should take care of most knocks ( provided the donor motor is good ). The tranny gears will be a little different ( at least some will be ).
    Howdy
    Jul 2012
    Manitoba
    5
    Thanks Howdy. The big red is a chain drive with high-low. I may be wrong about the reverse feature, the guy said it had, but wasn't 100% sure. Once I have it apart, i'll re-post details.
    Jul 2012
    Manitoba
    5
    Here are some pics of the Big Red and also the donor engine. I was surprised to find both the starter and the hi/low box on the donor engine!
Name:	83 big red.jpg
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by frenchy View Post
    Just swap motors because they are the same. 200m's didn't have hi/lo. You just saved yourself a LOT of work and money!!
