84 200ES All Ball Steering Bearings?
I know there was a post on here recently but i just can't turn it up with the search that showed someone replacing the ball type bearings with the All Balls roller bearing kit and i can't find it. Can someone point me to it or give some pointers to answer questions?
I helped do one of the all ball kits on the steering before, i have used their wheel bearing kits numerous times and they seem to be good quality. I know recently it was discussed that the top and bottom races and bearings are different heights, i think the taller one went in the bottom? And there was some discussion about a washer on the bottom that had to be between the seal and the bearing or was it between the seal and the fork crossmember, i don't remember now.
I know its going to be a major PITA to get that lower race off but if all else fails i know someone with a press that i could beg to help pop it off.
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
