In high rev cut out ?
I gota 185 Honda new carb and spark plug. It cut out , bogs down and has little back fire or kind of popping noise. When idle all the way. Took gas cap off does not help. Any ideas.
deacceleration pops usually indicate a lean carb. What main jet is in the new carb?
I have tried a couple diffrent carbs. This is the another 185 I have it not same one. The other 185 runs great thx
The one the needle slides in and out of. The largest one in the stack.
Not sure can ? Do I just measure it
//ArrowChat Integreation Code
