Results 1 to 9 of 9
Thread: Old Balloon Tires
    Sep 2007
    California, USA about 50 miles north of sacremento
    976
    Old Balloon Tires
    Where can I find some balloon tire valve stems?
    PA
    3,515
    Valve stems are valve stems as far as I know.
    WWW.HREATV.COM
    Sep 2007
    976
    Yes, but this tire does not have a inflation like normal tires, it says "Max inflation 63 IN Outside circumference". I believe that it has a 2 way rubber valve. I think that when the tire presses in some air is pushed out and when the tire goes back in air is sucked back in. This is for suspension right? I seen some on ebay yesterday but now can't find them. They were little rubber plugs NOT like normal stems.
    Also it has this symbol on it (what does it mean?):
    Uploaded with ImageShack.us
    Sep 2007
    976
    So not many responses, did I stump all the forum geniuses?
    Mountain Home, AR 72653
    500
    use regular valve stems, tire gauges come with a small tit on the opposite side just for letting air out. This is what I would do, all the cicumferance measurement is for is so you don't over inflate and so your rears are even and the bike does not pull to one side.
    1984 Honda 200X
    1999 Kawasaki Bayou
    2000 XR 200
    Mar 2005
    ma
    988
    read a post on replacing these stems in the old 6 wheeler balloon tires. you use regular valve stems. but the problem is getting them in. normal rim you pull them out from the inside, you can't do that on the balloon tires. have to push it in from the outside. forget how they did it, but you can get them in, just a pain.
    suspension action comes from the balloon tire , all that extra rubber tire helps them flex to absorb impacts. no 2 way valve stems.
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
    Apr 2002
    s.w. michigan
    6,498
    Well Rich, as for myself in saying,,,, IMHO ,,, will say about those "symbols". I don't know guy,,, where do I go with this.
    Could they be abstract or simply ejector pin/mold clasping pin markings, I chose the latter being molding fixture markings. They can be made to resemble anything from your aunt to something totally allian.
    Ever thought about making them ?
    Baltimore, MD
    6,088
    Wow. The forum geniuses aren't stumped, we know the answer. LOL Firstly the 63 inch outside diameter is for your safety. At the normal pressure, if the tire has a larger outside diameter than 63 inches, the tire was technically considered trash. I also believe what you may be looking at, which is very hard to tell by your picture, could be a plug. The valve stem, was built into the rim, which was molded into the tire itself.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Sep 2007
    976
    So what is the method to putting a new stem into the rim from the outside?
