Results 1 to 15 of 15
Thread: 200x issue cranks over then stops
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    So last night was pounding the crap out of my rebuilt 200x on the trails . Then it started to make noise when i gave it the gas. It was fairly loud ticking only when i revved it .
    It was doing that for about 1 min then died . I didnt want to damage anything so we just towed it home . So today while trying to diagnose it i noticed it would spin a few times then it would lock up . Once i backed it in the other direction with a wrench on the flywheel it would spin fine a fee times then sieze again . It does have good compression when it spins.
    What does this sound like ? Crank rod bearings ?
    84 200s almost done
    84 atc 70 project
    Jan 2011
    Choctaw, OK
    2,755
    Sounds like you need to pull the motor apart to diagnose your problem. It doesnt sound good any way you look at it.
    6,810
    Sounds like the large crank rod bearing . Either way its time to take it apart !!!!
    Slidell, LA
    4,738
    Sounds to me like your crank bearings are fried. Time to split the cases, have fun!
    Feb 2009
    greentown PA
    389
    Mother f'er lol. Figured as much . :-(
    84 200s almost done
    84 atc 70 project
    stevensj13's Avatar
    stevensj13 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Willow Springs, North Carolina, United States
    338
    wait, a ticking sound, then it only spings over so far? Thats a timing issue. your timing chain came loose and you jumped time, then running it like that, it jumped again, and now its far off enough to have the valve hitting the piston. It was exactly the same on a TRX 125 I had and that was my problem.
    My baby - 1984 Honda 200X, Clark Desert Tank, Supertrapp exhaust.
    May 2011
    eden,ny
    3,481
    if it is the rod bearing you should be able to rock the flywheel back and forth to feel any play on the rod. If by some chance it did jump time like mentioned above, you will probably have to replace valves at the very least. Pull the head off the problem will be easily diagnosed.
    Feb 2009
    greentown PA
    389
    Well i hear a banging noise and some slop when i turn the flywheel . I dont think its the valve because i can get a few full revolutions out of it before it stops . I am tearing the eneing apart tonight i have it out. Let you know what i find
    84 200s almost done
    84 atc 70 project
    Feb 2009
    greentown PA
    389
    the lower rod bearing is beyond fried lol split the cases earlyer .
    84 200s almost done
    84 atc 70 project
    Slidell, LA
    4,738
    Sorry to hear. While you are in there I would consider freshening all the bearings. Gives you a nice piece of mind.
    Feb 2009
    greentown PA
    389
    Thanks . Not sure what route to take on this . Does anyone know a good place to get a rebuilt crank or one that rebuild this one ?
    84 200s almost done
    84 atc 70 project
    Slidell, LA
    4,738
    If you buy the bearings and ship your stuff to mike at HRE, he would probably be able to press them on for you. He is also located in Pennsylvania.
    Mikes website:
    http://hreatv.com/
    Here is your rod bearing (don't know what year you have, this is for an 1983. But I thought they interchanged. Maybe do a bit of research first)
    http://www.ebay.com/itm/HONDA-ATC200...sories&vxp=mtr
    Here is a new connecting rod kit with bearing (stock rod)
    http://www.ebay.com/itm/HONDA-ATC-20...sories&vxp=mtr
    Here are your crank bearings:
    http://www.ebay.com/itm/Honda-Crank-...sories&vxp=mtr
    Feb 2009
    greentown PA
    389
    Thanks a lot :-) .
    84 200s almost done
    84 atc 70 project
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by PAPA250r View Post
    any good enige shop should be able to turn the crank but is the bearing avaiable?If an undersize bearing is available what sizes can you get and how far down does the crank need to go? I would suggest getting it to a good shop.
    NEPA
    7,051
    These are press apart Ben. No turning or undersizes. That would have made WAY too much sense! Gotta know what you're doing sliding that new rod pin and bearing in there at 20 tons. The crank halves like to score real easy : )
