Results 1 to 15 of 21
Thread: To tube, or not to tube? That is the question.
    May 2009
    S.E. Michigan
    1,251
    So I cut the sidewall on my OEM 350x tire this weekend. It got pinched between the wheel and a stump. It really bums me out since the tire has very little time on it since new and the tire is now discontinued from Honda (apparently).
    The cut is about 1/8" long, and is a thin slit rather than a puncture like you'd get from a stick. It's about an inch or so from the bead on the sidewall.
    Anyway, I got the tire removed from the rim today and am prepared to patch both sides of the tire. I'm pretty confident that the patch will work, especially given the previous advice from Tapper to mount the tire with the patch to the inside of the machine (so that it won't see as much trail abuse in the future).
    The question is, should I just stick a tube in there anyway, in addition to the patch? Is there a downside to running a tube in the tire, other than the cost? Does it mess anything up having a tube on one side and not the other (I can't see why, but I'm just curious).
    I really don't want to have to buy a tube, but I also don't want to have to take the tire back in to have it broken down if the patch alone doesn't work.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Popeye is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2011
    MS
    301
    I don't know about trike tires, but a good patch or plug in a vehicle tire will out-last the tire more often than not. Sucks that you popped it though. I guess that's what happens when you use these bikes the way they were meant to be used. I hit a tree this weekend and bent my dang near mint front forks on my 81 200. But without brakes, it was either hit the tree or go off something I didn't want to go off lol.
    1984 Honda ATC 300r (Project Trike)
    1981 Honda ATC 200 (Daily Rider/Hunting Trike)
    MN
    3,260
    I would patch it and put in a tube just to be safe, then you don't have to worry about getting stuck with a flat somewhere. My 84 200ES has tubes in both rear tires, they just had a slow bead leak somewhere that i got tired of trying to fix. I know it was the bead cause you could spray them down and get a bubble now and then depending on how it was sitting. Cleaning the wheels didn't help, no dings in the edges either, so i finally said the heck with it and put a tube in them. If you do put in a tube get the T6 valve type, its the metal valve stem with a nut on the outside and washer on the inside. A standard tube will slip eventually and pull the valve sideways cause the pressure is so low on these tires.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Sep 2009
    Suring Wisconsin
    967
    I would patch it and see if it holds. You can always tube it later. remember also if you tube it you need to do both rears, other wise it will handle weird.
    Rebuilding and riding trikes everyday and lovin every minute.
    http://www.3wheelerworld.com/showthr...light=pipeline
    blackstone/ma
    1,491
    Patch it and if it just leaks a little slime it. I slime everything and it's great. I would buy new tires before I tube them just the way I roll
    Nov 2004
    Waterloo IL
    2,701
    On a 350x I would try not to use a tube. The combination of low air pressure and power I think the chances of the wheel spinning inside the tire and shearing the valve stem off the tube are pretty high. If it was an ATC70 then yeah put a tube in it.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Aug 2004
    Ab Canada
    4,368
    take it to your local ag,industrial tire shop and have it repaird, 1/8 inch is small, a properly done repair should hold no problem, just make sure its a proper biasply patch a radial one wont hold long..most small auto shops only carry radial boots and its forgotton, overlooked quite often.
    1985 Tri-Z-
    Big Mike's Avatar
    Hanson, MA
    1,062
    I run tubes in both of my 350x's rear tires and have never had an issue.
    Currently Own:
    1985 ATC 250sx
    1986 ATC 350x
    Projects/Parts machines:
    1980 ATC 185S
    MN
    3,260
    If i had to slime a tire i would replace it... I don't see why anyone runs that foul crap.
    Does tire slime work? Yes sometimes. Does it ruin the wheels and make it miserable to do replacements and repairs? Most Definitely...
    The tubes won't slip if you get the right type, unless your running like 50hp and nitrous i think you should be fine.. LOL.. I have never seen one of these slip a tube and shear off the valve. I have seen them spin a tire a bit on the wheel, but whats why you get the T6 bolted in tire valve on your tube, the tube rotates with the wheel and the tire is free to do what it wants to. Put some baby powder around the inside of the tire and on the wheel, this will allow the tube to slide around inside without much friction.
    Slidell, LA
    4,738
    1/8 inch isn't that bad of a slice. That being said, I have tried to patch sidewalls before and its never worked. After a couple hours of riding, they always failed, though, I had bigger slices in my tires. I second the opinion of putting a patch on and placing a tube in the tire. Double redundancy isn't a bad thing
    Sarnia, Ontario, Canada
    3,415
    Personally me, not a big fan of repaired tires..especially sidewall damage.
    I know that the pressures & speeds are alot lower than a car where we consider sidewall repairs on tires completely out of the question. But still when 30 miles back into the bush if your repair lets go it's a huge issue..
    If I was to fix a tire I would then demote it to field use on one of the machines that doesn't leave the farm property.
    If my main rider tires get damaged in any way they get replaced..but that is just my way!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Nov 2004
    Waterloo IL
    2,701
    I saw this guy sellin a bunch of sets on ebay so I figured they were readily available, I guess not. This set did not sell, email him and see if he still has them. They are cheap enough too! http://www.ebay.com/itm/Honda-OHTSU-...83e34a&vxp=mtr
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    stevensj13's Avatar
    stevensj13 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Willow Springs, North Carolina, United States
    338
    I used this weird rubber bonding compound stuff that melts rubber together, its some sort of glue. I used it on my old Tri-Z 250 tire when I had about an inch long dry rot crack on the side wall that gave out. Held up fine, didnt leak at all, it was great. Id reccomend giving that a shot. But, tubes are your friend. I tube everything when something goes wrong, quads, trikes, and mowers
    My baby - 1984 Honda 200X, Clark Desert Tank, Supertrapp exhaust.
    May 2009
    S.E. Michigan
    1,251
    Quote Originally Posted by Blown 331 View Post
    Man, I am kicking myself right now. I contacted that e-bay seller. They are an actual brick and mortar shop in Toledo (less than 1 hour drive away from me). I could have bought those and picked them up with no shipping. However, they have no more left and confirmed what another thread on here said: those tires are discontinued.
    I've been tempted about 1/2 dozen times when I was ordering other parts to order a set of these tires, but I always said "I'll wait until next order"... well, now it's too late. Darn.
    I'm still holding out hope that somehow they aren't really discontinued, but rather they are just waiting for more to get delivered from the manufacturer... but I don't think this is the case. Oh well.
    I'm not a fan of the green slime, although I must admit to having used it before. It really makes a disaster of your rims inside.
    I'm also having a heck of a time finding a tube of the proper dimensions (22x10-9). I was curious how much one would be.
    I think my plan is to patch inside and outside and give it a whirl.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Michigan
    1,144
    Years ago when I worked in a gas station, when we had tires that had a bad break we put a boot in it. A boot is nothing more than a big strong patch. This was before the days of radial and not alot of tubeless tires.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
