Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: To tube, or not to tube? That is the question.
    Nov 2004
    Waterloo IL
    2,701
    I always meant to order some stock dunlops for an 85 250r and never did. Can't get those anymore either. I ended up ordering stock tires for an 86, They look the same anyway. Maybe go with stock 300ex tires.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Jun 2012
    delaware
    100
    patch it then tube it. i got tiny shards of clam shell that stick into the tire and the only tires that go flat are the ones with no tubes. so now all of them have tubes and when i pry the pieces out they dont go flat.
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by hublake View Post
    Years ago when I worked in a gas station, when we had tires that had a bad break we put a boot in it. A boot is nothing more than a big strong patch. This was before the days of radial and not alot of tubeless tires.
    we still call em boots, did not want to confuse anyone, I still say its the best and proper way, both my buddys side by sides sufferd bad sidewall injuries on a poker run a while back from beaver stumps and rocks, I pluggef them on the trail and they held fine, booted up when we got back both have over 500km more of the same sharp rocky riding with no problems what so ever. also with a tube on the trail..theres no chance of plugging them, just my opinion do what evete you like and feel comfy with..but patching the outside of the tire wont do much.
    1985 Tri-Z-
    May 2009
    S.E. Michigan
    1,251
    Quote Originally Posted by MTS View Post
    I hear you guys. For sure, the main repair will be on the inside of the tire. I was going to put a patch on the outside just to sorta make a sandwich of the whole thing. I will keep my eyes out for a tube, but honestly, I've done some searching and don't see a 22x10-9 tube. Is there leeway to go with a tube that doesn't exactly match the tire dimensions? I wouldn't think so, but this is new to me. I've searched e-bay, amazon, rocky, denniskirk, etc. Haven't found one with my exact dimensions...
    In the meantime, I'm gonna patch it, mount it, then ride it a bit just around my parents place where I'm never more than a few minutes walk from the house.
    Thanks to all for all the info!
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by wonderboy View Post
    little biger is ok..as long as it dose not fold itself up too much in there, you will need to figure out the metric conversion, also alot of the tubes are a combination of a few sizes, check out the maxxis site, been a few years since I have stuffed one in a atv tire...either way you need to fix the hole in the tire first or it will pinch and leak, also if the inside liner of the tire is very rough texture you might run into problems with it chafing and puttin holes in the tube.
    1985 Tri-Z-
    Jun 2012
    delaware
    100
    ok just ripped a tire off and it had a tube. was doing donuts on the 250sx and ripped the tire off, the one that dosen't have a tube is still on. i don't know, mabey i'll just keep having fun and replacing the things i destroy. only cause it's fun!
