Results 1 to 15 of 16
Thread: Chain Slop
    Popeye is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2011
    MS
    301
    Chain Slop
    Went riding this weekend, but probably should have stayed at home instead. Hit a tree on my 200 and bent some really nice forks, pushed a mint fender back into my exhaust and melted it, threw my chain, and drove the most rusty, crusty nail I've ever seen into the side of my thumb and under the nail. (feels like my whole hand is gonna fall off). But had fun though lol.
    Anyways, I had just put a new chain on the trike but didn't replace the sprockets. Noticed some slack in the top of the chain and it was scratching at the front sprocket on the bottom end. I'm thinking the rear end may be out of line because when I was replacing my brakes the rear end slid over a little bit in the carrier. I pulled it back and thought I had lined up. Might be off though. But what about the slack in the top of the chain. Will new sprockets fix this?
    Thanks.
    1984 Honda ATC 300r (Project Trike)
    1981 Honda ATC 200 (Daily Rider/Hunting Trike)
    Nov 2004
    Waterloo IL
    2,701
    Maybe I'm misunderstanding but the chain being loose on top is no different than being loose on the bottom, just tighten it up.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Oct 2011
    MS
    301
    My bad, I meant to mention that the tensioner is all the way tight. I guess it is no different whether the slack is at the top or bottom, but I replaced it originally because it was kinda falling off the bottom. Now it just seems to be sagging at the top. You'll have to excuse my ignorance lol- been riding for a while, but not working on them.
    Take a link out of your chain.
    Nov 2004
    Waterloo IL
    2,701
    You bought a new chain and its still loose with the axle adjusted all the way back? Sounds like the new chain might be too long.
    Edit. Fabio just beat me.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    Oct 2011
    MS
    301
    I'm looking at the manual and I think I am reading it right. If the adjusting nut is all the way tight on the bolt does that mean the axle is adjusted all the way back? If so, then yea I am gonna have to remove a link. Thanks for mentioning that. Why would that happen though. Just from being old? I bought a chain for a 200, so it shouldn't be too long.
    Thank ya'll
    Nov 2004
    Waterloo IL
    2,701
    Maybe your front sprocket is smaller than stock? That would make a stock replacement chain too long.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    Either sprocket could be a different size from stock.
    Oct 2011
    MS
    301
    I can just count the teeth huh? I thank both of ya'll for walking me through it. Looking at it closely now I think my rear axle is off line. Is there an easier way to tell than just eye balling it?
    Sarnia, Ontario, Canada
    3,415
    Quote Originally Posted by Popeye View Post
    I got bit concerned by what you said in your 1st post, but everyone else is talking about your chain and sprockets. Have you checked the rear carrier bearings? A loose rear axle will mean you'll never get your chain tension right..plus alot more damage in the very near future!
    With the chain off and machine supported yank on the rear axle in all directions..there should be no movement.
    Sounds like you may more repairs in line beside your trashed forks!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    I meant to come back and add what Doug just said. I was a bit busy when I posted earlier.
    Just like he said though, you need to take a look at what's going on back there and find out why your axle isn't where it should be.
    Oct 2011
    MS
    301
    I checked the rear axle before I replaced the chain and it had no movement. I've got the chain off now and I will check it again. It fell out when I was doing the brakes. Thought I had it lined up, then wasn't sure, but looking out it now it seems fine. There is a little less than a 1/4'' gap between the rear sprocket mount and the carrier. My chain sounded like it was scraping the bottom end, but I think it may have just been the chain rattling because it was loose because I don't have any scrape marks down there. The front sprocket did seem a little loose though, but the 3 bolts were tight. I'm gonna count my sprocket teeth, check the rear end for movement, and then if that is all okay take a link out of the chain. Probably need to replace the sprockets but I am short on funds.
    Edit: The 1/4'' gap I mentioned is just between the flat part of the sprocket mount and the carrier. The tapered part of the mount is nearly flush with the carrier. Also there is absolutely no movement in the rear end. Bearings should be fine then right? Still don't explain why everything is tight and the chain is loose. Anybody else feel like the more you try to fix these machines the more damage you do lol? I month ago I had a raggedly looking trike that ran like a top- put $500 in it and it is falling apart lol. Kinda like a rusty radiator that don't leak- you flush it out and all the sudden it's pouring water lol.
    Only thing left is to count the teeth on the sprockets. Anybody know the stock sizes for an 81 ATC 200?
    Oct 2011
    MS
    301
    I think stock gearing is 11/47 and my rear sprocket is a 43 tooth. Chain is a 90 link like it is supposed to be. There's my problem I guess. Should I buy a sprocket or shorten the chain? Kinda relieved that it wasn't anything worse. I'll probably go ahead and get both sprockets when I get paid at the end of the month. Buddy's got a front end I can borrow until I get mine straightened. I'll start another thread to ask about that.
    Thanks to all of ya'll for your patience and expertise- especially fabio. I know he doesn't have much time for ignorance lol.
    Miami,Fla.(305)
    808
    Cheaper to shorten the chain (free). You would gain more pulling power if you go back to a 47 tho -if you dont mind buying the sprocket. But you would lose a little top speed which you dont really need on that thing anyway. Your call........
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Oct 2011
    MS
    301
    I was thinking shorten the chain too, but I'd be worried about having to guess and getting it too tight or not tight enough. Probably end up just buy new sprockets. Have to think on it. Thanks for your opinion and letting me know the difference. Pulling power is more important to me on this bike. But, right now I can smoke my buddy's 185s but he is having carb issues though.
