Results 1 to 15 of 15
Thread: 185s exciter/stator not lasting long
    Miami,Fla.(305)
    808
    O.k.- I've been thru I believe 6 of them within about 2 1/2 - 3 years. This last one was a new ($40 RM Stator) lasted about 5 rides. I thought it would last longer since it cost more than the others. I've put on 3 USED OEM ones & 3 different new & used aftermarket ones.(no NEW OEM ones for obvious fact that its around $200 for the assembly). Some of the aftermarket ones were actually thicker than OEM...... Now- the only explanation I have is the moisture trapped in the stator/flywheel housing along with the high temps in my storage shed when sitting. Now, I do ride thru LOTS of deep water/mud each time. I have pulled off the pullstart off after riding to see little trickle of water come out -nothing major (only normal right?) I dont belive it ever fills up or anything. I've checked the housing days later to find moisture all around the flywheel etc.... I have my pullstart sealed off for the most part. New OEM handle ,good rope recoil, gasket in place. I've seen them less sealed off without a problem. I dont think its anything else electrical causing it like wiring, conn.,faulty CDI or coil, cap, etc.. O.K.- My question is :has anyone else gone thru this so frequently? Also I noticed the exciters dont seem to be really sealed up( just wrapped in string basically).-Can I try using automotive silicone to seal up just the exciter coil? Or spray WD40 before & after riding everytime? Anyone else done it? I was tempted to spray it with WD40 before but figure it may cause more harm than good (short circuiting?). & the silicone gives off corrosive fumes as it cures so not sure thats a good idea either.................Why doesnt anything happen to the lighting coil? Anyone else gone thru this? Or is it just bad luck? (of which I have plenty) Any other ideas anyone?
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    6,817
    My theory is they just get to hot and fail , poor cooling design at the flywheel . You never here of a 81-85 atc 110 stator going bad and its the same stator (motors run much cooler ). Those 185s motors run very hot . I have a customer that brings me his 200x about every 6 months with a bad stator and as you know its submerged in oil so I dont believe its a moisture issue at all but more of a heat issue . Run a wet clutch synthetic oil and a oil cooler if possible and I think it will last longer . You do have the little cooling fan on the flywheel right ?
    Miami,Fla.(305)
    808
    Yeah Mike -it has the fan blades & its mounted the right way too. Motor is stock except for a 10.25 to 1 comp. piston & a header which add a little heat I guess. Doesnt higher comp. makes it strain harder to create spark too? Gap was always correct ......I know its not running lean. What about using a little of that special paste/grease (whatever it is) & apply a little behind where the exciter mounts (where it mounts to the round plate). Its the stuff you find/use under an ignition module on a car/truck. Its used to keep heat transfer down. (U know what I'm talkin bout?) -not sure what its called. I just may pull the clutch cover/oil cooler off of the other 185s since its not getting/going anywhere. ......Got exciters? .Thanks
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    6,817
    The high compression piston will for sure make it run hotter than the stock dished style piston . The elect paste isn't the issue IMO , you just need to get the motor temp down . Your not to advanced or retarded on the pulse generator are you ? 93 octane fuel might help as well .
    I'm looking for a nice 185s seat foam if you have one ?
    Grant should have the stators .
    Miami,Fla.(305)
    808
    The electr. paste wont help youre saying? I figured it would serve the same purpose.-it was just a thought....No -the pulser is not + or -. Been runnin strictly 92 except for 1 or twice in a pinch & put 87 (ran fine). - I have the seat foam that I got from U - (for the "Warlock" 185s). Just sittin there & no seat cover yet......
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Jun 2009
    Leander TX
    2,217
    Are all your grounds and connections clean, secure and corrosion free?
    Miami,Fla.(305)
    808
    Quote Originally Posted by jb2wheels View Post
    Yeah-its all good harness (untampered & undamage in any way.) low hrs, no corrosion, etc. ,good conn. & ground- its all been gone over multiple times anyway. Wire loomed harness/ heat shrink on the conn. Bike runs thru DEEP water like its not there & no sputtering/or misfiring ever. I do ride it/run it very hard tho- So heat might be culprit like Shortline10 said.
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Pacific NW
    4,255
    Not sure if it matters but I was running the tractor hard with 8 inches of heat ripples off the
    exhaust.
    Stared at it for hours and ran low on 'gas'.
    Came up to the barn and all I had left was non ethanol fuel.
    that we use for the trikes and chainsaws etc.
    I figured an extra dollar to get the job done was worth the waste.
    lo and behold, the heat waves off the muffler dropped
    to UNDER 2 inches high.
    I thought alcohol might have a cooling effect but I guess it runs hotter.
    Miami,Fla.(305)
    808
    Hmmmm.....interesting- but I'm not so sure gasoline is avail. anywhere around here without 10% ethanol. I would be avoiding that 10% ethanol in the other vehicles too if I could. (It hurts MPGs)
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    6,817
    Truck stop at Griffen road and state road 27 sells the ethanol free gas , pump # 13 out back . I buy it their all the time . I run it in the bass boat and the atc's .
    Quote Originally Posted by 3wheelrider View Post
    Miami,Fla.(305)
    808
    Alright -cool. Dont really ever venture that way anymore since Holeylands closed in '08 (I used to pass by that gas station to go riding on the weekends)- but hey...I'd like to run that non-e in the 250R as well. Don't they have like 100 octane or something as well or was it race fuel? I believe I remember correctly?
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    6,817
    I think its like 95 octane at Griffen . I believe the shell station at pines blvd and 27 sells the race fuel but its prob like 8 or 9 bucks a gal .
    Miami,Fla.(305)
    808
    Thanks again Mike.....
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Pacific NW
    4,255
    small airports for av gas or
    boat marina fuel is commonly alcohol free.
    google ethanol free gas. I posted a national map a while ago.
    outta the way stations in small town cater to logging companies, airplanes and freaks like us.
    Miami,Fla.(305)
    808
    Thanks for the info....
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
