Results 1 to 8 of 8
Thread: What tire pressure do you guys run?
    stevensj13's Avatar
    stevensj13 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2011
    Willow Springs, North Carolina, United States
    338
    Hey guys. trying to come up with a good tire pressure to run on my 84 200x. It has flat wide, MX style tires on the rear, I forget the exact type. Its got your average trike tire on the front. My riding area doesnt have a lot of rocks, just mainly dirt, roots, and sticks. some wet stuff too but I dont mud my trike, only trails. What is everyone running for pressure around here?
    My baby - 1984 Honda 200X, Clark Desert Tank, Supertrapp exhaust.
    STL
    3,560
    i dont have a guage that reads low enough, so I just use feel. I either push my knee into the tire and see how hard it is and repeat to match on the other side
    Im guessing its probably around like 3 or 4 psi total though.
    Sarnia, Ontario, Canada
    3,415
    I like 2 PSI in most of my tires..especially on the rocky trails to avoid puncture. But when you run this low it's really important to keep the rear tires extactly the same..the torque of acceleration will cause the machine to steer in the direction of the lower tire. The more torque the machine has the worst the effect!!
    If you put 5 PSI in one and 2 PSI in the other on your TRI-Z or 250R and run it you'll see what I mean..it may vary from one tire to another more!
    There are low pressure gauges that go from 0-15 on the market..I bought a handful of them on Ebay a few years back and keep them on all my boxes.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    stevensj13's Avatar
    Jun 2011
    338
    Quote Originally Posted by JasonB View Post
    I like where my rear tires are, but the front is really soft. it seems to handle fine so I havent changed it.
    stevensj13's Avatar
    Jun 2011
    338
    Quote Originally Posted by dougspcs View Post
    I think since theres not many rocks on my trails I'll try 4 psi. I've got a guage that goes from 0 to 30 that I like to use. Thanks for the tips!
    3,415
    Quote Originally Posted by stevensj13 View Post
    4 PSI is good too..it's like a mattress. Everyone likes a different feel..
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Slidell, LA
    4,738
    I second the "tire feel" method. I don't use a gauge, I put my weight on one knee and adjust that way. Also note, tire pressures (as you probably know) are different for track, trail, rock, flat, etc.
    I run lower pressure on rocky trails (Ozarks) and I run firmer pressures on tracks.
    stevensj13's Avatar
    Jun 2011
    338
    I agree. I usually check with my hand, for soft stuff I like it mushy, I like the pressure the tires are at now, It turns really sharp, doesn't tip easily, and the front tire leads instead of getting pushed, but I was thinking of playing around with it a little bit. I just bent my shifter back straight today so tomorrow I'll go for a ride and see how I like 4 PSI
