Thread: t3 just started and no top end power
    i just started my t3 for the first time and after about 1/2 throttle it begins to die. the engine is breakin up alot upon acceleration.could this be because i am running a 32:1 mix???every now and then the idle will raise all by it self.
    after rebuild it only took 4 kicks to start, i loved it!
    i was a nice guy and waited till 10 am this morning to start her up, man it's loud!
    my neighbor has a 85 t3 that he says needs a head gasket and wants 500 bucks for it , think i might pick it up for parts. question is , if water is in the oil the only way to enter engine is through the head??????
    85 tecate original, stock
    for sale :84 tecate complete,8inch+swingarm, complete rebuilt engine,dg type2 , ,douglas aluminum rims with realtors, new stator and fly wheel.
    70 something hodoka ace 100
    84 lt185
    Jun 2002
    Mississippi
    2,552
    it sounds like your jetting or timing is way off.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,245
    water in the oil means your water pump seal is badthats the only place water and oil cross,,,,,,,,
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Kasey said it.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    mbg75 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    Long Island
    256
    check your reeds. a broken reed will keep the bike from reving up but it will idle ok. also check for vaccum leaks.
    if you don't buy the 85, i'd be interested in it.
    Back on 2 wheels for now!
    clean 86 350x for sale.
    picked up the 85 t3 last nite , took it for a spin and every thing works.looks like this thing is a cherry,none of the bolts have scraches on them and nothing has been repainted.
    plan on rebuilding the engine"piston , rings , seals and gaskets and i am going to try to trade a kx 250 for it.
    84 lt185
