I need a new fuel line from my petcock to my carb for an 83 185s. Does anyone know how big of a fuel line it takes (as far as diameter)? Tried looking on ebay, the manual, and google and no luck. Thanks
Is there any left on the trike? Just take that to your local auto parts and match for dia. and get a foot. Should only be a couple of bucks/ ft.
Russ J in SW PA
83 Honda 200 (fishing and hunting "rig")
83 Honda 185 (parts)
95 Polaris Xplorer 300 4x4 (WIP)
Here is a listing on eBay for a OEM Honda 200x fuel line and it will work, you will just have to cut off what you need, listing shows you get a 7inch long fuel line. All the 185's - 200's have the same diameter fuel line. http://www.ebay.com/itm/110928681313...ELX:IT&vxp=mtr
3/16" fuel line
Previously Owned:
1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
1981 ATC 185S
1984 ATC 250R
1981 ATC 250R
1983 ATC 110
1969 HONDA MINI TRAIL 50
TRIKELESS
