Results 1 to 12 of 12
Thread: Small Blind bearing puller
    blackstone/ma
    1,491
    Wanted to get a Blind bearing puller to pull the water pump bearing out. THe one HF sells is to big. I need on that goes down to like 1/4 inch. Anybody know of a cheap kit I could buy??
    Slidell, LA
    4,738
    Here's a shadetree method that works. A cheap blind hole bearing puller could be made from an off the shelf drop in anchor expanded within your ID and than hooked to a slide .
    http://m.homedepot.com/p/Hilti-HDI-1...ack/100325185/
    Grande Prairie, Alberta, Canada
    96
    Pack grease into the cavity and then use a dowel and a . The hydraulic action will pop those suckers right out without having to pry on anything risking breakage.
    Quote Originally Posted by H2Sbass View Post
    I had that same thought but I'm pretty sure the grease would just slide right through the bearing.
    blackstone/ma
    1,491
    I tried that before and it didn't work for me I ended up putting the case half on the grill for 20 minutes and they fell out but those bearing are like $30 so if I buy a puller now in the long run I will probably save money
    zzmegad's Avatar
    zzmegad is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2008
    North of Chicago
    317
    I think the tusk set is your best bet, I think 8mm is what you need
    http://www.rockymountainatvmc.com/p/...earing-Remover
    mollie8000's Avatar
    mollie8000 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2009
    kentucky
    170
    dont use grease,use bread,but easy with the ,
    blackstone/ma
    1,491
    Thanks man I just bought one :-)
    Quote Originally Posted by zzmegad View Post
    Scootertrash's Avatar
    In the sticks
    4,638
    Great!! I just spent 80 bucks on some new tools and now you post this. I haven't need anything like this for awhile but have always wanted one.
    blackstone/ma
    1,491
    yea well the small bearing is like 20 buks and every time I sand blast a case I have ot buy a new one so in the end it will be cheaper. Or at leas that's what I tell my self....lol
    Jun 2011
    Clovis, California, United States
    30
    I just spot welded a long bolt to the bearing that fit inside the bearing with the mig welder and popped it out. same bearing your talking about on the water pump. you need a new bearing anyway. it worked perfect for me.
    blackstone/ma
    1,491
    ATCJeff told me to put them on the grill and they fall out!!!! Worked like a charm. To be honest I Just like owning tools. I got a case splitter (awesome BTW) clutch tool, pullers bla bla bla. I just like the ease of getting the correct tool and geting a job done. I did everything shady tree as a kid and made it work somehome but now that I can afford some of this stuff I like acquiring it. Hopefully my kids someday don't burry them in the yard like I did to my dad's tools. I'm starting ot realize why he got pissed when I would trash his shop lose his tools and then act oblivious..lol
    Quote Originally Posted by dirtflinger66 View Post
