Results 1 to 11 of 11
Thread: Will 86-87 200x forks Slide right into my 85 tri-z triples?
    Shawn72's Avatar
    Shawn72 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Lawton, Ok
    392
    I know the 83-85x forks are smaller diameter.
    It's a celebration bitches!!!
    Kentucky
    2,294
    The forks are the same, 83-87
    Tionesta Trikes ATC 450R
    86 250R
    86 Tecate-3
    83 ATC 70
    85 Big Red
    81 KLT 200
    85 250SX
    Shawn72's Avatar
    Jul 2006
    Lawton, Ok
    392
    Ok thanks Eric
    IDK if all the Z's were 39MM but the 85/86 Honda 250R fork is 39MM's.
    I know nothing else that is involved.
    You guys determined to keep our dinosaurs ought to be hopping on the NOS forks on EBAY for about 400$ with boots,clamps,axle and collars.
    They use to run 700$ or better.
    Husky250 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2010
    NE Ohio
    264
    The "X's" are 33mm. Same as a n early 2000's kx65, which I am mounting as soon as I can find someone to make me an axle.
    Abrams, Wisconsin
    739
    85 tri z fork tubes are smaller than 86, i think 35mm or maybe 36mm.... i've got 85 forks on mine i will measure and post back soon.
    86 250sx - old reliable
    another 82 110
    -gone but not forgotten-
    82? 110 - why did i sell it??
    84 225dx - meh, it was a pile
    Abrams, Wisconsin
    739
    confirmed, 85 tri z forks are 35mm.
    another 82 110
    I'm sure you know that they made an 85.5 Z too. Mosh or Raffa would know the size of that model.....
    Abrams, Wisconsin
    739
    ^^ pretty sure 85.5 is the same as 85, but yes those guys can confirm.
    another 82 110
    Rittman, Ohio
    6,276
    The "85.5 model" doesn't actually exist as a separate model, and was something that originated on the forums. You'll not find an OEM parts listing for an "85.5". The only thing that differentiates a late model 85 from an early model 85 is color scheme.
    na
    5,702
    Yes all 85's were 35mm..Same as 350X and some 200x's?..
    The 86 was 39mm like 3rd gen 250R's. I have heard of guys boring 85 Z tripples out to accept the R forks and swaping the whole front end over.There is a host of benefits to this including an 11 inch front rim and now 10 inch rims, and superior braking system and suspension. However, the 85 Z had way more increased rake that was reduced with the 86 tripples. I would "think' IMO, for handling purposes in my experience with the Z, that the 86 tripples combined with the 250R front end may yield better handling characteristics. They don't push as much in the turns with the reduced rake of the 86 Tripples. IMO even the 86 Z forks allthough improved, were not as great in suspension as the 250R forks were stock for stock.
    Proudly NOT a member of
    "Team on the Teat"
