Results 1 to 10 of 10
Thread: 200x crank timing gear removal ... / service manual links
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    Any one have any tips on how to remove then reinstall one of these . ? Changing crank bearings .
    Also the last link i had to a service manual is dead :-(. Does anyone have one in pdf format for the 200x ? Thanks
    84 200s almost done
    84 atc 70 project
    Slidell, LA
    4,738
    Removal is easy. Do you have the cases split yet? If, so the crank just pulls out (bearings and all) because the bearings are press fit on the crank halves.
    Feb 2009
    greentown PA
    389
    Yea the engine is split . I got a replacement crank and new bearings but need my old timing gear .
    84 200s almost done
    84 atc 70 project
    Slidell, LA
    4,738
    the gear on the crank? it has to be pressed off. The new one you are getting from bryan will work.
    Jan 2011
    Choctaw, OK
    2,755
    To get it off, you need a split bearing tool. Pulls it right off. To install it, heat the gear and freeze the crank. The gear will drop right on but be quick about it. Heat the gear to about 400deg and deep freeze the crank overnight.
    6,798
    On the timing chain sprocket I use a small gear puller and to reinstall make sure a tooth is lined up with the flywheel keyway as close as you can get it and just tap it on with a deep well socket , they tap back on pretty easy .
    Nov 2007
    I have not check in a bit but look under world class help on this site. there is a 200x service manual.
    Chris
    Feb 2009
    greentown PA
    389
    Thanks for the info . Hopefully goes smooth lol
    84 200s almost done
    84 atc 70 project
    MN
    3,263
    Check my sig below.... I have a manual server up and running.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Feb 2009
    greentown PA
    389
    Thanks :-). Just what i needed
    84 200s almost done
    84 atc 70 project
