Results 1 to 11 of 11
Thread: "84 honda big red 200"-$1300
    St. Agatha, ON, Canada
    1,497
    http://kitchener.kijiji.ca/c-cars-ve...AdIdZ403588585
    shes in great shape runs top notch. has hi, low and reverse. no cracks in fenders, lights work. needs a brake handle + cable as well as a battery. also has pull start. call dewy at 519-635-3407
    1983 Honda ATC 200e: my first true Man Toy!-Sold for $200 on Victoria Day
    Ice & Trikes 4 Life!
    If Nissan Motorsports = Nismo, does Honda Motorsports = Homo ?
    Jul 2011
    Ontario/Quebec
    1,179
    Bit steep!!! payed 200$ for mine 29$ ebay(caltric carb),, and runs like a champqqqq.jpg
    1986 Honda 350X
    1985 Yamaha Tri-Z 250
    1,497
    Quote Originally Posted by sp8twn View Post
    yours is a 83 right, this is a 84 with shaft drive, possibly better cosmetics also.
    Jul 2011
    Ontario/Quebec
    1,179
    Nope 84 200ES,,,Shaft Drive HI/LO Reverse,,,it's a beast and still 1071$ cheaper!... and comes right out of your back yard i belive?(kitchener/waterloo areas) NOT Saying it's not a nice old and clean BIG RED (No suspention)!!!! But i could NEVER Pay that for something im only going to use as a tractor around the farm!!!
    Quote Originally Posted by Lord Letto 20 View Post
    1986 Honda 350X
    MN
    3,263
    If thats an 84 then someone swapped the rear plastics with another year, they aren't 84 200ES fenders i can tell that for sure!
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Jul 2011
    Ontario/Quebec
    1,179
    Good eye kbonly!!!!,,200M
    Quote Originally Posted by kb0nly View Post
    1986 Honda 350X
    philgipson's Avatar
    philgipson is offline At The Back Of The Pack Arm chair racerFirst time rider
    southwest texas
    219
    way too much 84 had bad front end and i think thats the only year they used that rear end.look for at least a 85.
    86 big red
    85 250sx
    85 atc70
    non illigitamus carborundum
    Jul 2011
    Ontario/Quebec
    1,179
    BAD FRONT ENDS!!!!!LMFAO!!,,,,YUP!!!!Welded mine with iron angle brakets!!!That 2inch suspention travel dont miss it at all!!!
    Quote Originally Posted by philgipson View Post
    1986 Honda 350X
    MN
    3,263
    Bad front end?? I can't say i have ever had any trouble with mine. And the rear end parts are easy to come by, but with the shaft drive you hardly ever have to do anything with them anyway, just clean and grease.
    philgipson's Avatar
    southwest texas
    219
    the bottom rust out of the legs and they dont realy have much travel.as for the rear i have seen guys on this site having problems with parts,one year manufacture.
    86 big red
    85 250sx
    85 atc70
    MN
    3,263
    Huh... I know of at least a half dozen 84's around here and i have never seen the bottom of the legs rusted out like you describe. If they are having this problem its most likely due to bad fork seals, poor maintenance, ripped boots on the forks, etc. I had mine apart to clean and relube them as well as replace the boots and they look good here. My 84 has seen a life of work on a farm and it has some rust but the forks are fine.
    Finding parts for the rear ends is easy peasy. I rebuilt one about a year ago. DrATV and a few ebay sources have all the parts to do a complete rebuild. I haven't really found anything unavailable for the 84 other than that sub trans shifter knob. Mine got broke so i had to make up a new knob for it. Other than that just about every part on the trike is easy enough to get. The only part that was totally NLA was the headlight wiring grommet but now we have a fantastic repo of that available.
