Just installed a new clutch lever and perch! Its so hard to pull back now i almost have to use both hands and im a pretty strong guy lol....
Any ideas what i could do to help free it up some? Do i need a clutch, cables or both? Thanks
Try lubing your cable.
Wd40. Try that to see if that works? You got a new clutch cause you flipped your R right? Hows that wound? Hope its healing up good
http://www.3wheelerworld.com/showthread.php/140404. My feedback thread
Make sure you guide the clutch cable
Correctly if not it will be stiff.
You can post some picture see if we notice
Anything incorrectly installed...
If you have Bought a item from me, Please leave me feedback
If your buying a item from me check my feedback
Click on link ~ http://www.3wheelerworld.com/showthr...ceaserthethird
Is the perch the same ratio as before? Some have the cable attatching point in different places. One of my MSR perches has 3 holes. The middle is supposed to be a stock feel. One is stiffer, and one is lighter. Is it something that changed only as a result of the new perch and lever?
Just a thought, did you over tighten the bolt that holds the lever into the perch? I've done that before...
1985 Honda 250r x2
1986 Honda 250r
1986 Honda 250sx
1985 Honda 250sx x2
1985 Honda 350x x2
1986 Honda 350x
1984 Honda 125m x4
1984 Honda atc 70
Yamaha tri zinger
Yamaha 4 zinger
Brap braaaap
On more that one occasion!!! :-)Just a thought, did you over tighten the bolt that holds the lever into the perch? I've done that before...
Really grooved outer clutch basket maybe?
Previously Owned:
1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
1981 ATC 185S
1984 ATC 250R
1981 ATC 250R
1983 ATC 110
1969 HONDA MINI TRAIL 50
TRIKELESS
Disconnect the cable and isolate it. Does the cable move eaisly and freely when its not hooked to anything? Does the lever move freely when there is no cable attached to it? In most cases the cable gums up to cause this. Sometimes you can force WD40 into it to flush it out, and get a little more life out of it.
Also while you have the cable disconnected if it moves freely, check your arm at the case with pair of short pliers on it, it should move fairly easy. Sometimes the needle bearings in the case around the actuator, get gummed up and siezed and bind the clutch arm actuator.
The 250R actually has an upper and lower needle bearing in the case that supports the actuator arm.
Proudly NOT a member of
"Team on the Teat"
Here's a thought, does the perch have a different mechanical advantage? what I mean is, does it pull the cable on a sharp angle as soon as it gets pulled? just wondering because it might make a difference..
My rides, 1985 ATC 350X, With legit Lamborghini Countach paint,2003 Harley Davidson FXDL Dyna Low Rider,customised the way I like it!
1997 GMC Sierra is gone, primary mode of transportation, 2008 Toyota Yaris!
