I know I need new Reed valves for it. But what brand n style? It's stock virgin motor this first set being replaced on it. I'm looking for cheap but good set. Any one able to help out?
This is somewhat subjective bit I prefer the Boysen reeds. Boysen reeds give a bit more bottom end whereas the Vforce 3 reeds are more top end and give a bit more hit on the powerband but in my opinion the Boysen reeds are better for a general upgrade.
Boysen reeds
http://www.3wheelerworld.com/showthread.php/140404. My feedback thread
Where is a cheap place to get them at?
Is there a specific reason that you "need" new reeds? Or are you just looking for an upgrade? Just reeds are not going to give you a noticeable increase in performance. They will work "with" other upgrades, such as air filter, carb, etc., but by themselves...you'll likely never notice a difference.
Those who can ride, ride...those who can't, drive.
Boysen reeds are better all around then the vforce and they are around the sames price
Boyesen always used to offer OEM style replacement reed petals if you don't want to spend the $$$ on swapping the entire reedcage. If they still offer them that would be a more economical option.
As far as pricing, all the major brands (ESR, Duncan, V-Force, Boyesen, etc) are all in the same ballpark for entire reedcage setups. They will all run between $160 and $200 give or take a few bucks.
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
