Results 1 to 12 of 12
Thread: 1990 KTM 300exc opinions
    Amater45's Avatar
    Amater45 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2009
    Berlin, New Hampshire
    230
    Just bought one today, was wondering what everyones opionions on these bikes are, if anyone has had one
    Traded my ts100 for it.. sorry atc007
    1987 Honda FatCat -Gripper seat, +1 front sprocket
    1987 Honda TRX250x- Suppertrapp IDS2, +1 front sprocket, DuraBlue axle, HotCams, 10:1 piston, +2 widened
    1983 Honda 200e BigRed-Has a ViseGrip for a shifter, 'nuff said.
    1971 Honda Trail 90- Original Everything
    Previous Rides:
    1981 Suzuki TS100
    1990 KTM 300exc
    southern maine
    67
    KTM's are known to be great trail bikes.
    I had a 98 380 EX/C and regret selling it all the time.
    I do suggest you become a member over at Ktmtalk.com
    Very good Informative site, no junk. And you get a discount on parts from some place in waco Texas i think it was. Munn racing maybe. That's where I got all my oem parts when I had mine.
    Have fun two wheeling! The only other way to go besides three wheelin.
    Amater45's Avatar
    Nov 2009
    230
    I only plan on trail riding as well. anything you recomend to check? and are there any infamous problems with these bikes haha
    Previous Rides:
    1981 Suzuki TS100
    1990 KTM 300exc
    Mexico
    9,014
    Check the chain, wheel bearings, steering head, shock links, etc. Unless you were good buddies with the last owner I'd pull the head off and take a peek in there. If it looks scratch free I'd change the oil and ride it. PS. Make sure the water pump seal isn't leaking into the crank case.
    Amater45's Avatar
    Nov 2009
    230
    I knew the guy, i know whats up with the motor. He was changing the oil in it when i was checking it out the other day, and water pump seal, gotcha. thannks!
    Previous Rides:
    1981 Suzuki TS100
    1990 KTM 300exc
    Amater45's Avatar
    Nov 2009
    230
    Previous Rides:
    1981 Suzuki TS100
    1990 KTM 300exc
    Mexico
    9,014
    Cool! Suggest you wear boots when you are starting that thing in the future.
    Amater45's Avatar
    Nov 2009
    230
    Well i found out there coolant leaking into the bottom end.. El Camexican, thanks for letting me know about the water seal! I would of been clueless without you letting me know haha. Im going to put a new bearing, seal, impeller, and gasket, flush the bottom end etc. is there anything else that could be causing a leak into the bottom end possibly? ive read that the seal is main problem. thanks!
    Previous Rides:
    1981 Suzuki TS100
    1990 KTM 300exc
    Mexico
    9,014
    Quote Originally Posted by Amater45 View Post
    Not that I can think of (unless something is cracked which I doubt). Make sure you clean the crankcase well. That means taking the clutch plates out and wiping off the coolant goo. Make sure the seal is installed "flat" to the cover and that you lube the seal and the shaft before you install it. I don't know your year, but I suspect it has a air bleed on one of the rads. If so, don't forget to bleed it when you fill the system and start it for the first time. Wait till the fluid heats up and starts flowing and then makes sure you are somewhere that spilling some coolant dosen't matter (it can kill a pet) when you open the bolt (Protect the eyes and hands!). Once its bleed close the bolt, open the rad cap and top the system off if needed. The next time it is cold check the level. The cooling tubes should be covered, but not by much, or you'll always be purging coolant when you ride and if you're like me the odor will freak you out "OMG! I've sprung a leak!" After you ride for a couple hours I'd change the crank case oil again. It will tell you if the leak is fixed and get rid of the last of the coolant that was still in the cases. If is all good, you should be fine for at least a few years of leak free riding.
    PS. Watched your video again. You need to lube your shock linkage.
    Amater45's Avatar
    Nov 2009
    230
    Thanks, its a 1990. What should i lube the seal and shaft with, the coolant? oh, and i lubed the linkage right after the video, i heard it too! haha
    Previous Rides:
    1981 Suzuki TS100
    1990 KTM 300exc
    Mexico
    9,014
    The same oil you plan to use in the trans.
    Amater45's Avatar
    Nov 2009
    230
    Ahh right, thanks again! Hopefully shes running again soon!
    Previous Rides:
    1981 Suzuki TS100
    1990 KTM 300exc
