I'm gettin ready to do a crank job, gettin all the stuff I need. I know the clutch actuator arm bearings are toast. Bike Bandit has the seal and lower bearing, but says the top needle bearing is discontinued. Part number 12 on the following diagram.......http://www.bikebandit.com/houseofmot.../o/m1909#sch12 Does anyone know where and what bearing to get? Acording to Bike Bandit it's a 10x17x10 needle bearing.
. Any helpful tips would be appreciated.
to pull it out.. much like an axle bearing puller for car rear diffs....Or a long dremmel bit, and carefully grind a slot in the race until it falls out..That would be a last ditch effort though. I am sure someone makes a blind hole puller to get down to that smaller size. I think that lower bearing is about 8mm.
