Results 1 to 15 of 16
Thread: 250sx progress
    mojave's Avatar
    mojave is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    southern indiana
    266
    250sx progress
    heres some before and after pics still need a few things for it like a front fender i was wondering if anybody knew whether or not a 350x would bolt up to the 200x front end. it won't hardly turn one way there is a piece of metal on the frame hitting the tripple tree i don't know if this is normal for the 200x front end swap.
    mojave's Avatar
    Feb 2003
    southern indiana
    266
    the last pic is the before pic lol
    STL
    3,560
    It might be all that crack i just smoked (jk) but the forks look like they are backwards to me.. like the actual forks are installed flip flopped. maybe I am wrong though> I think the metal you are hitting is the stoppers for the old tripple trees. They have to hacked off and re welded in different spots to keep from denting you gas tank more.
    late
    Apr 2002
    s.w. michigan
    6,498
    looks nice
    i like the look it gives the sx,,, just looks better to me. i am certain it will improve the ride a bunch. i had a sx for a year and was just darn near as stiff as my es is now.
    i just spent all day in the garage working on my 350x front end,,, it's on correct ATCaddict. i am sure you are right about the stops on the gooseneck though,,,
    john
    mojave's Avatar
    Feb 2003
    southern indiana
    266
    yep i never noticed thanks alot for making more work for me lol
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    No, I think you do have the forks on wrong, if I am correct, the 200x front end is suppossed to be a trailing axle, not a leading axle. I dont know if it will affect the handling or anything, but maybe someone else will know.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    mojave's Avatar
    Feb 2003
    southern indiana
    266
    i don't really know pilot i just looked at your post of yours and your forks where the hub mounts are turned the other way and your brake rotor is on the other side.
    Central PA
    1,952
    Yep, 200x's are trailing axles, you have yours on backwards. The only problem I see in this is that you wheel is further away from underneath the bike, and your turning, and front end traction might suffer, but I do like the extended chopper look it gives it. I guess that a 250R or 350x fender will bolt right up.
    PastRides
    SOON MY PRECIOUS!
    Apr 2002
    s.w. michigan
    6,498
    whoops !
    aw crap, i though i read he'd put a 350x front end on it,,, my bad.
    ( still like the looks of it like it is )
    reckon i oughta get off the crack too ATCaddict,,, lmao !
    john
    Eastern Long Island
    1,688
    Re: whoops !
    Quote Originally Posted by jeswinehart
    john
    And I thought it was just nitrogen narcosis!!!!!
    Lots O Trikes!!!!!
    mojave's Avatar
    Feb 2003
    southern indiana
    266
    does anybody know how to change the one way clutch in these things. how hard. i ordered a honda manual off ebay.
    mojave's Avatar
    Feb 2003
    southern indiana
    266
    ok guys got the forks on right still need to hack off the gooseneck stopper but it is really hard to turn could i have tightened everything to much? any info would be appreciated.
    Did you make sure all the ball bearings went back in. They all fell out me and i had to use tons of grease to hold them in place when i was doing my switch over. I really don't think you could have tightened it to tight. Yeah i hacksawed off the stopper also and never welded new ones back on. First ride out, dented my can without even knowing till i got back.
    mojave's Avatar
    Feb 2003
    southern indiana
    266
    yea i found all the bearings that was a pain it turns its just stiff
    Headlight guard
    Dude ill give you fifty bucks for the old sx headlight guard if you still got it
