Results 1 to 15 of 18
Thread: How do I rebuild a Honda pull starter?
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    This recoil I am working on is not like the Yamahas I have done in the past. I need some direction here. I remember a thread a long while back that laid out a step by step process on putting one of these back together. I cannot fond it now; I guess it is too old. Can some one please walk me through how to get this thing functional again?
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Howdy's Avatar
    Celina, Ohio
    10,079
    Jan 2005
    5,301
    I get the whole thing put together, but it does not work. Am I suppose to keep tension on it? I tried but it do not stay sprung.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Howdy's Avatar
    Celina, Ohio
    10,079
    Are you sure the ends of the main spring caught the tabs ( 1 on the case and 1 on the pulley )? There should be tension on the rope at all times so that the rope will pull in and hold the handle in position when not in use. if the spring ends are catching the rope will pull out and not go back in all the way or not go in at all.
    Howdy
    Jan 2005
    5,301
    I thought so. The spring ends are catching like they should. EVen though I kept tension on it as I assembled it, when i did a test pull the rope did nothing. I ulled itoutbut it didnot recoil.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Scootertrash's Avatar
    In the sticks
    4,638
    Once the tabs on the spring catch you need to preload the spring by 3 or 4 turns on the pulley (IIRC). It's been awhile since I rewound one. You can always put a couple of winds on the spring run the rope thru the housing and give it a couple of test pulls to see if it retracts properly.
    Jan 2005
    5,301
    I have not even installed it yet. I am trying to get it to recoil off the trike.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Howdy's Avatar
    Celina, Ohio
    10,079
    Pull the c-clip off the top and see if the pull starter retracts. If it don't then either the spring isn't catching or you need to add more rounds to gain more power. The pulley has a small knotch in it that will allow you to wind the pulley with the rope installed. Just pull a loop in the rope between the case and pulley and wind it up. If the spring isn't catching you should hear it slip as you wind the rope / pulley.
    Howdy
    Jan 2005
    5,301
    I will try that tomorrow. I am wondering if I am widning it wrong.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by LonesomeTriZ View Post
    Your doing this part 100% correct!!!
    Alway, Always, Always test the pull starter BEFORE installing it.
    Howdy
    Jan 2005
    5,301
    I figured it should work off the engine before it would work on it.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Howdy's Avatar
    Celina, Ohio
    10,079
    If you had the main spring out it is possible that you put it in backwards. Seen that a few times.
    Howdy
    Jan 2005
    5,301
    I left that thing right in place. I took everything else out though.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Howdy's Avatar
    Celina, Ohio
    10,079
    Jan 2005
    5,301
    Great video! I isntalled the rope first, then tride to wind it. No wonder it does not work.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
