What tire pressure are you running on your Trike or Quad? and why?
i find that the recommended pressure of 2.5psi? is just too soft and I run closer to 8 rear and 10 front lbs of pressure in my atc250sx and around 5 lbs all around in my trx200sx
Sometimes it seems like I should be running less pressure, but It just feels like the 250sx should have a bit more pressure than recommended in front to make turns...
maybe this is just because I am too used to riding the harley. Would i be better off to just stick with the stock 2.5psi?
This isn't a flame thread, so keep negative comments to yourself.
Please tell us what pressure you run and why.
Thanks
-D.
s almost needs no air at all.
