Im telling you. Mine had the exact same symptoms. It was a wire getting pinched/pulled from the handle bars.
I been through the wiring. Nothing it pullled to tight or broke. It has the stock main jet in it. The intake boot is ok with no leaks. For some reason it seems to flood itself out. The jet is 112.5. I tried a 105 jet it didn't make a difference. I had it running with the valve covers off. The valves seem to be working good. I'm hoping I can get another carb from a junk yard down the road. If this doesn't work there might be a dr for sale lol
is the seat for the slide needle still in the carb? if that happened to fall out with out you knowing is would flood out no matter what jet was in it.
I took a carb to another place and they adjusted the float. Brought it back home and still does it. I just don't get it. Next step maybe a weak intake spring and or a wore out cam? I checked for pinched or broken wires and found nothing. Keep the ideas running.
As stupid as it sounds I would check your fuel shutoff valve. Mine was doing the same thing. I pulled it off and cleaned the fuel filter and still had no luck. It would run awesome as long as it was set on reserve. I bought a new one and wallah it ran good as new.
Current Trikes
2 1985 Honda 250sx
1985 Big Red
2 1983 YTM 200k's. 1 for parts.
KLT 250 Prairie
1982 Honda 185 - Waiting to be saved
1985 125m Parts Machine
Still on the hunt for a 1986 350x and 250r.
I just want to thank everyone for there help. Who would have thought in 1985 Yamaha put a rev limiter on there tri moto. After cleaning the carb and going through everything I never tried to ride it. Stupid me I guess. Thanks again. Tecate project next!!!
Glad you figure it out you helped me out with gettin mine goin
my rides
1985 yamaha tri moto 200ERN (yellow)
1985 yamaha tri moto 200 (its blue)
1985 yamaha tri moto 225DR (black an gold)
1984 yamaha tri zinger yt60 (blue)
1984 Honda ATC 200ES Big Red (x2)
1981 Honda ATC 200
1985 Honda 200X new to the gang!
1986 Honda 250sx
2008 Yamaha Grizzly 700 moded(gone but not forgotten)
2008 Honda Rancher 420
Feedback thread. http://www.3wheelerworld.com/showthr...tickinto3wheel
LOL you got my sympathy. When i got my 225 I had a hell of a time with it before I figured out it had the wrong pilot jet and the former owner adjusted the throttle cable all the way to make it run so as soon as I started it after rebuilding the carb I thought it was going to blow. I would have never guessed it had a rev limiter.
