Thread: ATC70 part interchange? 79-85
    az
    2,001
    bought a 79 atc 70 a few weeks ago. got it fired up and it pops out of first gear, and has bad rear bearings. Only paid 100 bucks for it and thought it would be worth fixing up. Well today I picked up a 85 atc 70 that I was going to use for parts
    but this one had a motor with good compression, good bearings. the tires are junk, throttle cable is gone, coil wire is missing, plastic is busted up.
    So the 79 is officially going to be the parts bike, going to move as much over to the 85 and call it good. SO, aside from the 85 having a upshift 4 speed, does everything else from a 79 fit a 85? Of course when I traded my last atc70 project I threw in a couple good wheel/tires and I could use them on one of these projects. jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    Michigan UP
    1,005
    All of the parts should swap out between the 2. The only big difference is the transmission, the shift pattern and number of gears.
    Nov 2004
    Waterloo IL
    2,701
    Agreed. It should all swap over. There are some differences such as handle bars, grips etc but it will all still swap. I have a 79 that was jumping in first gear. I had a 1980 parts bike so I just swapped engines. I read of another guy on here about a month ago who had first gear problems in a 79 as well. Weird.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    az
    2,001
    I originally posted a wanted ad on the local craigslist and got a offer on a pitbike motor and a 185 that was totally trashed. Then this thing showed up and the seller was thinking it was a gold mine. Only thing its got going for it, is the motor seems to have decent compression, the front and rear axle bearings are decent, and the tank has some rust but not the ugly gross stuff and the air box, pull start is all there. Im going to swap the tank, carb and plug wire and see if it runs. Then I have to decide what to do with the 79. I hate to sell it because everytime I do, I come across another project that needs parts. jim
    81 185s
    82 185s
    and a 72 ct70
