Well i did a full rebuild since the 70 was burning oil. I installed the 88cc kit from dratv, new valve seals, valves cleaned , heavy duty springs, and there racing cam. Started up fine, ran ok but something wasnt right. Started smoking a little by the top of the engine. Everything was oiled when i put it together. Wasnt making much power, so i toook the engine back apart. Absoulutely no oil in the head, and the passages were completely dry!!!!. Cam was nice and black from overheating and the outside bearing was dark colored and slightly scored.. Im assuming thats where my smoke was coming from and why it didnt make any power, There was no lubrication up there. The oil pump worked before i did the rebuild. I did clean the oil screen out in the bottom of the engine, and filled the engine back up with oil. Do you think the pump failed? Screen in wrong???Anyway to test if its pumping oil?
Thanks
