Results 1 to 15 of 23
Thread: Lets see 2nd Gen R Front Forks on 200X
    Jun 2009
    Tunkhannock,Pa
    904
    I wanna run 2nd Gen R front forks on my 200X. If i can find a set of decent 250R forks and find someone to machine my 200X triples. So lets see some pictures of 250R front ends on 200X's
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    6,808
    Forks
    Here ya go , both my 200x's have them !
    Found a couple more recent pics .
    Attached Thumbnails Attached Thumbnails 200x3.JPG   200x6.JPG   sparks11.JPG   sparks12.JPG   sparks13.JPG   srp200xx.JPG
    Jun 2009
    Tunkhannock,Pa
    904
    Thanks Mike Its definitely the next thing i wanna do to mine. I also like the tank shrouds on number 55
    1985 200X
    66mm H&S Piston
    Bassani Exhaust
    Sep 2003
    Brookville,PA
    1,408
    What are the advantages of this? Do you have to use the 250r tripples?
    ontario
    1,131
    I did the full 250r front end swap over the winter also did the 350x rear shock swap to, it wasn't that easy the 250r stem was smaller in dia and much longer then the 200x, I ended up boring out the 250r tree and shaving it done to I think 17mm to get it to all go together http://www.3wheelerworld.com/showthr...28stage-one%29
ID:	153077Click image for larger version.
ID:	153078Click image for larger version.
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    torque's Avatar
    torque is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2011
    saskatoon sk canada
    308
    here is my set up. had the 200x triples bored to accept the new forks.
    @hillbilly how did you mod affect the front rake. steering and handling an d what not
    Slidell, LA
    4,738
    The easiest way is the way torque did it. Just have the triples bored to 35mm. Your stock 200x triples are 33mm so you still have enough meat on the triple to prevent cracking. Boring to 35mm will allow you to run the 83-84 250r front end.
    ontario
    1,131
    the rake was pushed out a little more i found that it handled a little better over stock in sand and hard pack and it was aloud ed me to use the front brake a little more when going into a shape corner. all in all i am very happy with it bu i may go back to the 200x trees like ever one else is running. One bad thing about the 250r trees is that you can't run the 200x head light, thats why i had the dumb 3'' lights on mine
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    Lets see the price you get on "boring triples". They aren't easy to hold/mount etc and it has to be dead nutz........
    Slidell, LA
    4,738
    Quote Originally Posted by torque View Post
    Torque, how much did your bore job cost?
    ontario
    1,131
    it cost me $80 seeing how they only had to bore out one hole
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    torque's Avatar
    Aug 2011
    saskatoon sk canada
    308
    it cost me big cash 300 bucks canadian. thats why i wanted to know if it was worth using the 250r triples. the shop that did the work said that they could do the next set for about half. they spent lots of time trying to clamp them in the fixture to get the angle right on.
    Slidell, LA
    4,738
    Interesting. That's quite a bit of cash.
    Jun 2009
    Tunkhannock,Pa
    904
    hmmm so it sounds like the cheaper route is to use 250R tripples and have them bored out to accept a 200X steering stem. Gives me something to think about Thanks guys I appreciate the impute
    1985 200X
    66mm H&S Piston
    Bassani Exhaust
    Slidell, LA
    4,738
    Quote Originally Posted by RodKnockRacing View Post
    Yeah, it is the cheaper route, but not the easiest.
    That amount of money sounds like a lot to me, not saying its wrong, just shocked by the sticker price. I have a local machine shop in St. Louis that does all of my boring work. They just bored my front fork stabilizer (from 55MM to 61MM) for 20 bucks and it had to be dead-nuts on as well. I wonder what they would charge to bore your triples? They are slow as hell, but perform very precise work. If you are interested in getting a quote, send me your triples and I will take them over to the shop for you.
