Thread: 86' 200x Ignition Coil?
    Matrix's Avatar
    Matrix is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2011
    Newton Falls, Ohio
    379
    When I attempted to pull the ignition coil Boot from my spark plug today I noticed it came apart like http://www.ebay.com/itm/86-HONDA-ATC...82eaf7&vxp=mtr . Does this mean that my ignition coil is broke or usable? Also it was very hard to pull off and I actually had to unscrew it from the top of the spark plug. Looking at my manual, it looks like there should not be that little thing on the very top of the plug (the thing you would unscrew and discard to expose the threads on the top of the plug) then the boot would go right onto the threads right?
    NEPA
    7,049
    While I'm not 100% sure off the top of my head. Both ends will " unscrew" out of the boots. Trim the wire back a 1/4 inch to fresh wire,and reinstall.
    Matrix's Avatar
    Oct 2011
    Newton Falls, Ohio
    379
    **Update**
    I figured out after about 4 seconds of looking at the boot that it actually screws onto the wire. Also, you do take that little thing off the top of the plug to properly insert it into the boot.
    Also, how do we update the title so it says update?
    NC
    907
    Quote Originally Posted by Matrix View Post
    **Update**
    Go to first post, click edit post at bottom of post #1, then click go advanced at the bottom of the post, then edit away.
    Matrix's Avatar
    Oct 2011
    Newton Falls, Ohio
    379
    Quote Originally Posted by 200x350xtriz250 View Post
    Awesome, thanks!
